electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
How to measure current in PCB trace?
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> How to measure current in PCB trace?
Author Message
Antonyb
Helped: 1
Post07 Nov 2009 10:53
What method is best to use for measuring the current flowing through a path in a PCB. Will it be better to use a current sense resistor or a current transformer?
I need to sense a pulse current whcih will be ON only for short duration (Of the order of usec).
Back to top
LM317
Post07 Nov 2009 12:20
Re: How to measure current in PCB trace?
you should use a sense resistor and measure voltage on it by using oscilloscope..
Back to top
Antonyb
Helped: 1
Post07 Nov 2009 12:30
But the current which I am expecting to be flowing is of 100A (Remember pulsed). Moreover the applied voltage will be of 300V. Will a CSR be a good way of measuring the current?
Back to top
hakeen
Helped: 16
Post07 Nov 2009 12:43
Hi
For best linearity, resistor would be a better choice. In transformer, you will have more serious non-linearity problems.
Your range of current (100A) is still OK for many resistors. Just try to use as small as possible value to lower overall consumption.
Cheers
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
svhb
Helped: 14
Post07 Nov 2009 13:33
It depends also on how short the pulses are. Be sure to select a low inductance type sense resistor.
If the frequency is moderate, you can consider a LEM current transducer. This has the advantage of an isolated measurement from the high voltage. (http://web4.lem.com/docs/products/la%20100-p%20e.pdf, this type has a 200kHz bandwidth)
Stefaan
Back to top
dick_freebird
Helped: 45
Post07 Nov 2009 20:33
If you have a known good spec, or better yet a 4-point
(Kelvin) measurement of the trace without power applied,
for trace resistance per length then you can use that and a
simple voltage difference reading to get your current
without having to cut and add a sense element. Though
PCB traces are meant to be pretty low resistance, so if you
are looking at low currents that would test the sensitivity
of your voltmeter perhaps. Not in this case.
I have seen current transformers that have that high a
saturation current, advertised. That needs a cut and a loop
of wire.
You could float your 'scope with an isolation transformer
so that the "ground" potential comes from the 'scope
probe, and see the pulse using the trace resistance as your sense.
100A is a mighty high current for a PCB trace.
Back to top
biff44
Helped: 244
Post08 Nov 2009 7:12
With 100A, there will be some serious magnetic field in the area of the conductor. Try a hall effect sensor.
Back to top
stan4
Post08 Nov 2009 7:30
CSR would probably be your best choice.
PS: I'm curious, I can't figure out what kind of application requires useconds pulses of 100 amps and also to measure it.
Back to top
FvM
Helped: 766
Post08 Nov 2009 10:57
Seriously, the question for best method can't be answered without a full specification. An AC only measurement generally
suggests a current transformer or di/dt sensing (Rogowski) coil. Both provide high bandwidth, isolation and low interference
susceptibility, the latter also insensitiveness to DC currents and effectively unlimited overload capability.
But the particular specification may be a reason to prefer other methods.
Back to top
Antonyb
Helped: 1
Post09 Nov 2009 5:03
Am planning for a current measurement ways now, since the PCB is not yet fabricated I will not be cutting the track and all. Am looking for which method would be the best one to measure the current.
As all of you have stated, the CSR would be the best method for liner measurements. But can you also suggest few Hall effect sensors for PCB mount?
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
HOW TO MEASURE PCB TRACE RESISTANCE (4)
Measure of natural PCB trace impedance (1)
PCB Trace current capacity (3)
How inductance affect PCB trace... (1)
How to measure a DC current? (4)
How to measure small AC current (8)
How to measure dielectric constant of a PCB (8)
Efficiency of PCB Antenna - How to Measure ! (3)
How to measure AC current RMS value? (13)
How to measure a capacitor's leakage current? (11)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
