| Author |
Message |
habib83
07 Nov 2009 9:28 Reflectarray CST simulation |
Dear all,
I want to simulate a reflectarray in CST2008. In Tsolver, when i use a horn as feed, the results are not valid. In I-solver the simulation do not converge (horn or ff-source)! and in F-solver a plane-wave source lead in RCS, only!
Would you please help me?!
| Back to top |
gracia
09 Nov 2009 17:49 Re: Reflectarray CST simulation |
Halo,
I'm also doing the same thing with you, maybe we can share something in common. This is my final project, reflect array antenna in S-Band. Until now, I'm still confusing about how to design the reflect array. I've already built the reflector, but for the feed I don't know where to put it and how to simulate. Because, usually I just simulate the antenna, not without the reflector. Can somebody help us please? thank you in advance
| Back to top |
Google AdSense
09 Nov 2009 17:49 Ads |
| Back to top |
abdoeng
Joined: 22 Feb 2004 Posts: 685 Helped: 14 Location: EGYPT
10 Nov 2009 18:58 Reflectarray CST simulation |
Hi all
what your reflectarray types?ring,slot,tl,patch?
habib,what is your problem exactly
i already run many reflectarray under cst 2008
i may help if you specify your problem accurately
so we here try help us
regards
abdoeng78
| Back to top |
winsonwhy
10 Nov 2009 20:25 Re: Reflectarray CST simulation |
Hi friends,
I'm also working on reflectarray. Let share our experience and knowledge.
Currently i have two project in reflectarray, both also 10x10 elements array. The first project is about using dielectric resonator as the element and the second project is about using copper patch as the element.
What i trying to achieve is when the reflectarray reflect the wave all the wave will have the same phase when reach the collecting point. Rough idea is to using horn antenna as feed and another horn antenna as the receiving point.
Currently, i'm using CST to analyze the behavior of the reflection phase for single element. What i try is build the single element and using a elevated waveguide port to launch the wave and observe the behavior of the reflected phase.
| Back to top |
abdoeng
11 Nov 2009 15:25 Reflectarray CST simulation |
hi winsonwhy
if you enter ieee,you will see 2 papers of dra reflectarray
for me,i already design dra reflectarray(x band and ku band)
i also design circular polarized dra
now i try to simulate electronic beam scan dra but i didn't get any ideas now
at all i may help you and sharing our ideas
i already simulate 31*31 elements
regards
my email:abdoeng78(at)gmail.com
| Back to top |
answa
18 Nov 2009 14:27 Re: Reflectarray CST simulation |
Hi guys . I work with reflectarray recently and i try to build 20*20 elements using microstrip patch antennas.
As a start i'm trying now to simulate 3*3 array fed by a horn antenna , i use CST MICROWAVE STUDIO 2008 .
the problem is that i can't find the farfield from the array , i always get the farfield of the horn antenna with some perturbation % original horn pattern ......
Can anyone help out me plz ......
Added after 2 hours 43 minutes:
I appreciate any help regarding how to simulate reflectarray antennas project in CST.
| Back to top |
