electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
The importance of loop gain
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> The importance of loop gain
Author Message
sikhjumn
Post07 Nov 2009 8:35
I'm confused about the usage of loop gain of Op Amp.
Can anyone tell me the importance of loop gain,e.g. open loop gain&close loop gain?
Thx a lot.
Back to top
LvW
Helped: 242
Post07 Nov 2009 10:30
Re: The importance of loop gain
Thx a lot.
Yes, sometimes one is confused, but it is important to know the difference.
There are three important gain parameters:
1.) open loop gain: gain of an amplifier without feedback (Aol)
2.) closed loop gain : gain of an amplifier with feedback (Acl<Aol)
3.) loop gain: gain of all components of the (open) loop. Example: opamp with resistive feedback: loop gain L= Aol*F (F=feedback factor R1/(R1+R2).
___________
The loop gain L is the most important parameter for stability investigations.
Back to top
sikhjumn
Post07 Nov 2009 10:52
Thx your answer.
Maybe...Are there any practical example for loop gain?
Or any example that the loop gain directly affect the results?
While i search the loop gain through internet, the example always based on mathematics. However, I need more examples baesd on macro views, or any product based on the principle of loop gain.
Back to top
LvW
Helped: 242
Post07 Nov 2009 15:22
* One typical example was given in my first answer
* based on the classical feedback scheme, Blacks formula shows the importance of the loop gain L(jw):
Acl=Aol/(1-Aol*F)=Aol/(1-L)
(Notation as in my first answer)
* The sign of L determines if you have positive or negative feedback, and don`t forget: L=L(jw), which means that L decreases (and its phase changes!) with rising frequencies
* Special case: If there is one frequency with |L|=1 (0dB)
and phase of L is 360 deg, the circuit design for amplification will become unstable.
*Recommendation: Try to become familiar with stability criteria; the you will see the importance of loop gain.
Back to top
fencl
Post09 Nov 2009 5:41
Yes, as LvW said ,loop gain is most important in some case. such sc circuit for adc.
but, a litter confused me is the simple way of ac analysis for loop gain and phase?.since i've known how to do for Aol and Acl. can you help for this,LvW
ths a lot.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
LvW
Helped: 242
Post09 Nov 2009 8:06
ths a lot.
You ask for a way to measure/simulate loop gain?
This subject has been discussed intensively in this forum before.
For example, have a look at "similar topics" at the bottom of this page.
LvW
Back to top
fencl
Post09 Nov 2009 12:24
[quote="LvW"]
LvW
oh, i've got it ,thx!
Back to top
fencl
Post13 Nov 2009 3:07
Hi, LvW,
since i follow the loop gain simulation way.i've got singal-end output gain&phase ,it works well. but when i try to the similar way for fullydiff-opamp. it become strange.
usually i needed is sc circuit in adc or fullydiff in pga.so i still can't use it for identification.
have you simulate for fullydiff before? can you share some experience?
Regards!
LvW wrote:
ths a lot.
LvW
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
what is the difference between loop gain and close loop gain (11)
loop gain and closed loop gain (10)
loop gain and closed loop gain (8)
what's the main input in the calculation of a loop gain? (2)
Question on the loop gain/phase (20)
how to test the open loop gain? (5)
How can measure the OP open loop gain? (12)
How to simulate the open loop gain of a buffer? (9)
How to measure the open-loop voltage gain of a OP?? (17)
How to simulate the dc open loop gain v.s output range (4)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
