electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Matlab Simulink Application that fits the following specs
Post new topic  Reply to topic    EDAboard.com Forum Index -> Digital communication -> Matlab Simulink Application that fits the following specs
Author Message
imonline888
Post07 Nov 2009 8:22
Hello. I am a newbie in Matlab Simulink. My professor gave me some specifications and parameters and my task is to find suitable application/system to be simulated in matlab by using Simulink. Below is the specs he gave:
Input Freq: 12KHz
Transistion band: Fs(start) - Fs(stop): 0.255-0.355
Input signal (voltage): 1.6 V
ripple voltage: 0.02 V
clock frequency: 120KHz
the system must be with 12-bit input discrete signal
the system must be with N-bit from 3-4 bit
the system must be using the supply voltage not greated than 2.5V
I should be able to show how I design my zero and dc gain and reach the desired SNR for N bit input using POwer Spectrum Analysis. I should also use the vale Fs within voice bandwigth range.
I would like to come up with a matlab simulation by using simulink. I think it may not be necessarily that the system uses all of those specs as long as it has almost all of the specifications required. I am also allowed to add some specs bases on my design as long as Im using almost everything he had specified.
Pls help me...thanks in anticipation
--- --- Bless and more power
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
i need the matlab code for following microwave topics (1)
Is DAC Specs realted to Reconstruction filter Specs (2)
How I use tektronix matlab waveform in MATLAB simulink? (2)
which FPGA board fits this requirement? (2)
matlab simulink? (2)
matlab simulink! (2)
Matlab n simulink? (4)
simulink to matlab??? (3)
simulink in MATLAB (1)
Matlab / Simulink (1)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
