| Author |
Message |
Sanath Embedded
07 Nov 2009 8:02 80W Power Measurement in Multimeter |
Hi Guys,
From the 400v DC, 80W o/p source I want to measure the power whether it provides the accurate 80W. How can I test it. is it possible with multimeter or any other technique.
| Back to top |
hameeds01
Joined: 23 Aug 2005 Posts: 285 Helped: 11 Location: NUST Islamabad
07 Nov 2009 9:57 Re: 80W Power Measurement in Multimeter |
yes u can do it via multimeter,
Power = volt x current
put a load of 0.2 Amps on the source & read the voltage across the load
e.g
power = 0.2 x 400
power = 80w
| Back to top |
Google AdSense
07 Nov 2009 9:57 Ads |
| Back to top |
Sanath Embedded
07 Nov 2009 10:28 80W Power Measurement in Multimeter |
| What load of 0.2 Amps I have to connect
| Back to top |
vipinsaini
07 Nov 2009 11:55 Re: 80W Power Measurement in Multimeter |
Dear if u don't have any load of 0.2A then u can connect a resistance of 2kohm at the output side for the purpose of 0.2A load.
But resistance should not be less than of 80W.
Thnaks & Regards
Er.VIPIN SAINI
DELHI(INDIA)
| Back to top |
hameeds01
07 Nov 2009 16:18 Re: 80W Power Measurement in Multimeter |
P = V x I
P = V² x R
R = V² / p
= 400² / 80
R = 2kΩ
Use R = 2kΩ , 80w ++
| Back to top |
