electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Voltage regulator with a buffer + voltage divider
Post new topic  Reply to topic    EDAboard.com Forum Index -> Power Electronics -> Voltage regulator with a buffer + voltage divider
Author Message
rprodrigues
Helped: 1
Post06 Nov 2009 16:48
Hi guys,
I do need your assistance again.
This time I plan to get 5v from 7v, and to do it I will use a simple voltage divider to get 5V from 7V and pass it trough a buffer (opamp), so I get it stable at the output side of the regulator (opamp).
Is this schema a power safe one or it would wast a lot of power?
I plan to use the 5v to supply a lot of ICs in my circuit.
How could I know that ?
Thank you
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
FvM
Helped: 766
Post06 Nov 2009 18:38
It's not a good method to design a voltage regulator. If you intend a linear regulator (you have another thread on VR efficiency), a industry standard 3-pin regulator is most simple, e.g. 7805 respectively 78L05 for lower currents. An OP limits the output current to about 20 or 25 mA, and it won't like bypass capacitors. An OP buffer can be a solution for a reference voltage supply.
But a 12 to 5V linear regulator wastes 140 mW for each 100 mW sourced at the output.
Back to top
rprodrigues
Helped: 1
Post06 Nov 2009 20:02
Re: Voltage regulator with a buffer + voltage divider
You are right.
That circuit is not a good one for the purpose I said you.
What I need is to get 5v from 7v but without using a switching regulator and achieving the better efficiency possible. A simple way to do this would be using two 1N4004 diodes in series so I can get about 5V when under 1A.
Any suggestion?
Thank you.
Back to top
FvM
Helped: 766
Post06 Nov 2009 20:22
A 7805 is able to create stable 5V with 7V input, a low-dropout regulator can work down to a few 100 mV voltage difference.
As said before, selecting a suitable linear voltage regulator hasn't to do with efficiency. It's very simple, the power
dissipation is basically (Vin-Vout)*Iload. So it's of course more efficient, to use 7V Vin instead of 12V Vin.
Back to top
rprodrigues
Helped: 1
Post06 Nov 2009 22:27
FvM,
The problem is that I plan to achieve the better power efficiency I can since my circuit is connected to a battery.
And If I use a LDO and before running the power lead to it I passed it through a series diode to decrease the power voltage about 1V. Could it be a more power efficient solution ?
Any suggestion about a LDO ?
Back to top
Mr.Cool
Helped: 24
Post07 Nov 2009 1:43
original schematic is NOT a voltage regulator at all.. it is a voltage divider.
i agree with FvM.
another option is to use a 5.1V zener diode as your regulator but i don't know if that's any more efficient than the linear regulator.
Mr.Cool
Back to top
rprodrigues
Helped: 1
Post10 Nov 2009 2:49
Guys,
I decided to go with an LM2675 from National!!!!
It is a switching regulator with a wonderful efficiency (about 86% ~ 90%).
Thank you very much!
Very Happy
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
fixed voltage regulator vs adjustable voltage regulator? (4)
Can a voltage divider act like a voltage amplifier? (15)
switching regulator voltage ripple vs. output voltage level (4)
Voltage Divider ground change to negative voltage (5)
About voltage regulator - changing output voltage (5)
Problem with voltage divider. (4)
Voltage Reference Circuit vs. Voltage Regulator (3)
Voltage Divider with Capacitor? Help! (4)
Help with wiring a voltage regulator (23)
help needed with the voltage buffer (1)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
