electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Problem interfaceing PIC18F2550 and KS0108 LCD
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> Problem interfaceing PIC18F2550 and KS0108 LCD
Author Message
hkBattousai
Helped: 4
Post06 Nov 2009 17:43
Re: Problem interfaceing PIC18F2550 and KS0108 LCD
I've been trying to interface 18F2550 and a 128x64 pixel graphic LCD for weeks. I tried several libraries found on the web, but none of them made the LCD print a single pixel on the screen. I'm really stuck at the moment, and I need guidance and new ideas.
The best library I found so far is the one I found in a forum. You can access the thread from here. For simplicity, I'm going to add source source code of the library below.
I also checked the signal levels at both PIC and LCD pinouts by an oscilloscope, there are meaningful pulses, the system PIC is working for sure.
The major parts I used are listed below:
  1. IDE: MATLAB 8.40 Academic
  2. Compiler: Microchip C18 3.34 Academic
  3. LCD: WG12864B, with KS0108 Controller (Detailed datasheet, Electrical specifications)
  4. PIC: PIC18F2550, with 20MHz crystal(Page, Datasheet)
These are photos of my LCD:
Front, Back
And these are photos of my circuit:
Front, Up
glcd.h
#include <p18f2550.h>
#define GLCD_Data   PORTB
#define b_GLCD_GCS1 LATCbits.LATC7
#define b_GLCD_GCS2 LATCbits.LATC6
#define b_GLCD_RS   LATCbits.LATC0
#define b_GLCD_RW   LATCbits.LATC1
#define b_GLCD_E    LATAbits.LATA5
#define b_GLCD_On   LATCbits.LATC2
#define b_GLCD_BL   LATAbits.LATA4   // Not used in my project
#define TRIS_Data    TRISB
#define b_TRIS_GCS1  TRISCbits.TRISC7 //GCS1
#define b_TRIS_GCS2  TRISCbits.TRISC6 //GCS2
#define b_TRIS_RS    TRISCbits.TRISC0 //RS
#define b_TRIS_RW    TRISCbits.TRISC1 //RW
#define b_TRIS_E     TRISAbits.TRISA5 //E
#define b_TRIS_On    TRISCbits.TRISC2 //RST
#define b_TRIS_BL    TRISAbits.TRISA4 //backlight
void Delay(void);
unsigned char GLCD_Read(void);
void Wait_Not_Busy(void);
void GLCD_Write_Cmd(unsigned char data);
void GLCD_Write_Data (unsigned char data);
void ClearScreen(void);
void Init_GLCD(void);
void PutChar(unsigned char data);
unsigned char GLCD_Read_Data(void);
void SetPos(unsigned char x,unsigned char y);
void WritePosition(void);
void plot(unsigned char x,unsigned char y);
void hline(unsigned char x,unsigned char y1,unsigned char y2);
void vline(unsigned char x1,unsigned char x2,unsigned char y);
void box(unsigned char x1,unsigned char y1,unsigned char x2,unsigned char y2);
void PutMessage(static char rom *Message);
void PutLogo(static char rom *logo);
glcd.c (a little long, but please bear with me)
#include "glcd.h"
const rom unsigned char Font[96][7];
unsigned char i,XPos,YPos,W;
void plot(unsigned char x,unsigned char y){
unsigned char d;
   if(x>63){
      b_GLCD_GCS1=0;
      b_GLCD_GCS2=1;
      x-=64;
   else
      b_GLCD_GCS1=1;
      b_GLCD_GCS2=0;
   GLCD_Write_Cmd(0x40+x);         //write column address
   GLCD_Write_Cmd(0xb8+(y>>3));   //write row address
   d=GLCD_Read_Data();            //dummy read
   d=GLCD_Read_Data();
   GLCD_Write_Cmd(0x40+x);         //write column address again
   d=d&(0xff-(1<<(y&7)));
   GLCD_Write_Data(d);
void hline(unsigned char x,unsigned char y1,unsigned char y2){
   for(i=y1;i<y2;i++)
      plot(x,i);
void vline(unsigned char x1,unsigned char x2,unsigned char y){
   for(i=x1;i<x2;i++)
      plot(i,y);
   unsigned char x2,unsigned char y2){
   vline(x1,x2,y1);
   vline(x1,x2,y2);
   hline(x1,y1,y2);
   hline(x2,y1,y2);
void Delay(void){
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
   _asm   NOP   _endasm
unsigned char GLCD_Read(void){
   b_GLCD_E=1;Delay();
   Delay();
   W=GLCD_Data;Delay();
   b_GLCD_E=0;Delay();
   return W;
void Wait_Not_Busy(void){
   TRIS_Data=0xff;
   b_GLCD_RS=0;
   b_GLCD_RW=1;
   if (b_GLCD_GCS1==1 && b_GLCD_GCS2==1){
      b_GLCD_GCS1=0;
      while (GLCD_Read()&0x80);
      b_GLCD_GCS1=1;
      b_GLCD_GCS2=0;
      b_GLCD_GCS2=1;
   else{
   TRIS_Data=0x00;
void GLCD_Write_Cmd(unsigned char data){
   Wait_Not_Busy();Delay();
   GLCD_Data = data;Delay();
   b_GLCD_RS=0;Delay();
   b_GLCD_RW=0;Delay();
   b_GLCD_E=1;Delay();
   Delay();
   b_GLCD_E=0;Delay();
void GLCD_Write_Data (unsigned char data){
   b_GLCD_RS=1;Delay();
   b_GLCD_E=1;Delay();
   Delay();Delay();
   b_GLCD_E=0;Delay();
void MoveRight(void){
   if(++XPos==64){
      WritePosition();
   if(XPos==128){
      XPos=0;
      YPos+=8;
      YPos=YPos&0x3f;
      WritePosition();
void WritePosition(void){
   if(XPos>63){
      b_GLCD_GCS1=0;
      b_GLCD_GCS2=1;
   else{
      b_GLCD_GCS1=1;
      b_GLCD_GCS2=0;
   GLCD_Write_Cmd(0x40+(XPos&0x3f));   //column=0
   GLCD_Write_Cmd(0xb8+((YPos&0x3f)>>3));   //row=0
unsigned char GLCD_Read_Data(void){
   Wait_Not_Busy();
   TRIS_Data=0xff;
   b_GLCD_RS=1;
   b_GLCD_RW=1;
   b_GLCD_E=1;
   Delay();
   W=GLCD_Data;
   b_GLCD_E=0;
   TRIS_Data=0x00;
   return W;
void ClearScreen(void){
unsigned char i,j;
   b_GLCD_GCS1=1;Delay();
   b_GLCD_GCS2=1;Delay();
   for(i=0;i<8;i++)
      GLCD_Write_Cmd(0x40);Delay();   //y=0
      GLCD_Write_Cmd(0xb8+i);Delay();   //x=0
      for(j=0;j<0x40;j++)
         GLCD_Write_Data(0xff);Delay();
   SetPos(0,0);Delay();
void Init_GLCD(void){
unsigned char i;
    b_TRIS_GCS1=0;Delay();
    b_TRIS_GCS2=0;Delay();
    b_TRIS_RS=0;Delay();
    b_TRIS_RW=0;Delay();
    b_TRIS_E=0;Delay();
    b_TRIS_On=0;Delay();
    b_TRIS_BL=0;Delay();
    b_GLCD_On=1;Delay();
    b_GLCD_BL=1;Delay();
   GLCD_Write_Cmd(0x3f);Delay();   //display on
   GLCD_Write_Cmd(0xc0);Delay();   //z=0
   ClearScreen();Delay();
void PutChar(unsigned char data){
unsigned char i,d;
   if(data<32){
      switch(data){
         case 13:
            XPos=0;
         case 10:
            XPos=0;
            YPos+=8;
            YPos=YPos&63;
      WritePosition();
   else{
      for(i=0;i<7;i++){
         d=Font[data-32][i];
         if(d!=0x55){
            GLCD_Write_Data(d);
            MoveRight();
      MoveRight();
void PutMessage(static char rom *Message){
   while(*Message!=0)
      if(*Message==0x16){
         *Message++;
         XPos=*Message++;
         YPos=*Message++;
         WritePosition();
      else
         PutChar(*Message++);
void PutLogo(static char rom *logo){
unsigned char w,h,bitcount,Byte;
   w=*logo++;
   h=*logo++;
   bitcount=0;
   do{
      for(i=0;i<w;i++){
         if(bitcount==0){
            bitcount=8;
            Byte=*logo++;
         if(Byte&1) plot(XPos,YPos);
         XPos++;
         Byte/=2;
         bitcount--;
      YPos++;
      XPos-=w;
   }while(--h);
void SetPos(unsigned char x,unsigned char y){
   XPos=x;
   YPos=y;
   WritePosition();
const rom unsigned char Font[96][7]={
   0xFF,0xFF,0xFF,0x55,0x55,0x55,0x55,   //   32
   0xFF,0xA0,0xFF,0x55,0x55,0x55,0x55,   //   33   !
   0xF8,0xFF,0xF8,0x55,0x55,0x55,0x55,   //   34   ""
   0xEB,0x80,0xEB,0x80,0xEB,0x55,0x55,   //   35   #
   0xD9,0xB6,0x80,0xB6,0xCD,0x55,0x55,   //   36   $
   0x9C,0xEC,0xF7,0x9B,0x9C,0x55,0x55,   //   37   %
   0xC9,0xB6,0xFF,0xDD,0xAF,0x55,0x55,   //   38   &
   0xFB,0xFC,0xFF,0x55,0x55,0x55,0x55,   //   39   '
   0xE3,0xDD,0xBE,0x55,0x55,0x55,0x55,   //   40   (
   0xBE,0xDD,0xE3,0x55,0x55,0x55,0x55,   //   41   )
   0xEB,0xD5,0xE3,0xD5,0xEB,0x55,0x55,   //   42   *
   0xF7,0xF7,0xC1,0xF7,0xF7,0x55,0x55,   //   43   +
   0x7F,0x9F,0x55,0x55,0x55,0x55,0x55,   //   44   ,
   0xF7,0xF7,0xF7,0xF7,0xF7,0x55,0x55,   //   45   -
   0xBF,0x55,0x55,0x55,0x55,0x55,0x55,   //   46   .
   0x9F,0xEF,0xF7,0xFB,0xFC,0x55,0x55,   //   47   /
   0xC1,0xAE,0xB6,0xBA,0xC1,0x55,0x55,   //   48   0
   0xFF,0xBD,0x80,0xBF,0xFF,0x55,0x55,   //   49   1
   0x9D,0xAE,0xB6,0xB6,0xB9,0x55,0x55,   //   50   2
   0xDD,0xBE,0xB6,0xB6,0xC9,0x55,0x55,   //   51   3
   0xE7,0xEB,0xED,0x80,0xEF,0x55,0x55,   //   52   4
   0xD8,0xB6,0xB6,0xB6,0xCE,0x55,0x55,   //   53   5
   0xC3,0xB5,0xB6,0xB6,0xCF,0x55,0x55,   //   54   6
   0xFE,0x8E,0xF6,0xFA,0xFC,0x55,0x55,   //   55   7
   0xC9,0xB6,0xB6,0xB6,0xC9,0x55,0x55,   //   56   8
   0xF9,0xB6,0xB6,0xD6,0xE1,0x55,0x55,   //   57   9
   0xEB,0x55,0x55,0x55,0x55,0x55,0x55,   //   58   :
   0x7F,0x97,0x55,0x55,0x55,0x55,0x55,   //   59   ;
   0xF7,0xEB,0xDD,0xBE,0x55,0x55,0x55,   //   60   <
   0xEB,0xEB,0xEB,0xEB,0x55,0x55,0x55,   //   61   =
   0xBE,0xDD,0xEB,0xF7,0x55,0x55,0x55,   //   62   >
   0xFD,0xFE,0xAE,0xF6,0xF9,0x55,0x55,   //   63   ?
   0xC1,0xBE,0xA2,0xFF,0xB1,0x55,0x55,   //   64   @
   0x83,0xED,0xEE,0xED,0x83,0x55,0x55,   //   65   A
   0x80,0xB6,0xB6,0xB6,0xC9,0x55,0x55,   //   66   B
   0xC1,0xBE,0xBE,0xBE,0xDD,0x55,0x55,   //   67   C
   0x80,0xBE,0xBE,0xDD,0xE3,0x55,0x55,   //   68   D
   0x80,0xB6,0xB6,0xB6,0xBE,0x55,0x55,   //   69   E
   0x80,0xF6,0xF6,0xF6,0xFE,0x55,0x55,   //   70   F
   0xC1,0xBE,0xB6,0xD6,0x8D,0x55,0x55,   //   71   G
   0x80,0xF7,0xF7,0xF7,0x80,0x55,0x55,   //   72   H
   0xBE,0x80,0xBE,0x55,0x55,0x55,0x55,   //   73   I
   0xDF,0xBF,0xBE,0xC0,0xFE,0x55,0x55,   //   74   J
   0x80,0xF7,0xEB,0xDD,0xBE,0x55,0x55,   //   75   K
   0x80,0xBF,0xBF,0xBF,0x55,0x55,0x55,   //   76   L
   0x80,0xFD,0xF3,0xFD,0x80,0x55,0x55,   //   77   M
   0x80,0xF9,0xF7,0xCF,0x80,0x55,0x55,   //   78   N
   0xC1,0xBE,0xBE,0xBE,0xC1,0x55,0x55,   //   79   O
   0x80,0xF6,0xF6,0xF6,0xF9,0x55,0x55,   //   80   P
   0xC1,0xBE,0xAE,0xDE,0xA1,0x55,0x55,   //   81   Q
   0x80,0xF6,0xE6,0xD6,0xB9,0x55,0x55,   //   82   R
   0xD9,0xB6,0xB6,0xB6,0xCD,0x55,0x55,   //   83   S
   0xFE,0xFE,0x80,0xFE,0xFE,0x55,0x55,   //   84   T
   0xC0,0xBF,0xBF,0xBF,0xC0,0x55,0x55,   //   85   U
   0xF0,0xCF,0xBF,0xCF,0xF0,0x55,0x55,   //   86   V
   0xF0,0xCF,0xBF,0xC7,0xBF,0xCF,0xF0,   //   87   W
   0x9C,0xEB,0xF7,0xEB,0x9C,0x55,0x55,   //   88   X
   0xF8,0xF7,0x8F,0xF7,0xF8,0x55,0x55,   //   89   Y
   0x9E,0xAE,0xB6,0xBA,0xBC,0x55,0x55,   //   90   Z
   0x80,0xBE,0xBE,0x55,0x55,0x55,0x55,   //   91   [
   0xFC,0xFB,0xF7,0xEF,0x9F,0x55,0x55,   //   92
   0xBE,0xBE,0x80,0x55,0x55,0x55,0x55,   //   93   ]
   0xF7,0xFB,0xFD,0xFB,0xF7,0x55,0x55,   //   94   ^
   0xBF,0xBF,0xBF,0xBF,0xBF,0x55,0x55,   //   95   _
   0xFC,0xFB,0xFF,0x55,0x55,0x55,0x55,   //   96   `
   0xDF,0xAB,0xAB,0x87,0x55,0x55,0x55,   //   97   a
   0x80,0xD7,0xBB,0xBB,0xC7,0x55,0x55,   //   98   b
   0xC7,0xBB,0xBB,0xD7,0x55,0x55,0x55,   //   99   c
   0xC7,0xBB,0xBB,0xD7,0x80,0x55,0x55,   //   100   d
   0xC7,0xAB,0xAB,0xB7,0x55,0x55,0x55,   //   101   e
   0xF7,0x81,0xF6,0xFD,0x55,0x55,0x55,   //   102   f
   0x67,0x5B,0x5B,0xA7,0x55,0x55,0x55,   //   103   g
   0x80,0xF7,0xFB,0xFB,0x87,0x55,0x55,   //   104   h
   0xC2,0xBF,0x55,0x55,0x55,0x55,0x55,   //   105   i
   0x7F,0x7B,0x82,0x55,0x55,0x55,0x55,   //   106   j
   0x80,0xEF,0xD7,0xBB,0x55,0x55,0x55,   //   107   k
   0xFE,0x80,0xFF,0x55,0x55,0x55,0x55,   //   108   l
   0x83,0xF7,0xFB,0x87,0xFB,0x87,0x55,   //   109   m
   0x83,0xF7,0xFB,0xFB,0x87,0x55,0x55,   //   110   n
   0xC7,0xBB,0xBB,0xC7,0x55,0x55,0x55,   //   111   o
   0x03,0xE7,0xDB,0xDB,0xE7,0x55,0x55,   //   112   p
   0xE7,0xDB,0xDB,0xE7,0x03,0x55,0x55,   //   113   q
   0x83,0xF7,0xFB,0xFB,0xF7,0x55,0x55,   //   114   r
   0xB7,0xAB,0xAB,0xDB,0x55,0x55,0x55,   //   115   s
   0xFB,0xC1,0xBB,0x55,0x55,0x55,0x55,   //   116   t
   0xC3,0xBF,0xBF,0xDF,0x83,0x55,0x55,   //   117   u
   0xE3,0xDF,0xBF,0xDF,0xE3,0x55,0x55,   //   118   v
   0xC3,0xBF,0xCF,0xBF,0xC3,0x55,0x55,   //   119   w
   0xBB,0xD7,0xEF,0xD7,0xBB,0x55,0x55,   //   120   x
   0xE3,0x5F,0x5F,0x83,0x55,0x55,0x55,   //   121   y
   0x9B,0xAB,0xAB,0xB3,0x55,0x55,0x55,   //   122   z
   0xF7,0xC9,0xBE,0x55,0x55,0x55,0x55,   //   123   {
   0xFF,0x80,0xFF,0x55,0x55,0x55,0x55,   //   124   |
   0xBE,0xC9,0xF7,0x55,0x55,0x55,0x55,   //   125   }
   0xFF,0xFF,0x55,0x55,0x55,0x55,0x55,   //   126   ~
   0x01,0x7D,0x7D,0x7D,0x01,0x55,0x55,   //   127
main.c
#include "glcd.h"
#pragma config WDT      = OFF
#pragma config MCLRE      = ON
#pragma config DEBUG      = OFF
#pragma config LVP      = OFF
#pragma config PLLDIV      = 5         // need 5 for 20MHz xtal
#pragma config CPUDIV      = OSC1_PLL2   // CPU Clock = 96 MHz/2 = 48 MHz
#pragma config USBDIV      = 2         // 96MHz PLL/2 = 48 MHz for USB clock
#pragma config FOSC      = HSPLL_HS   // High Speed Crystal / Resonator with PLL enabled
void main (void)
   Init_GLCD();
   PutMessage((rom char*)"\x16\x24\x08 Blueroom\x16\x20\x10 Electronics\n Title:\n Author:\n Date:\n Hardware:");
   PutMessage((rom char*)"\x16\x38\x18Graphic demo.");
   PutMessage((rom char*)"\x16\x38\x20Mike Webb.");
   PutMessage((rom char*)"\x16\x38\x28June 20 2007.");
   PutMessage((rom char*)"\x16\x38\x30Unicorn.");
   box(1,1,126,62);
   while (1);
   // Working "Hello World" example
   /*unsigned char i, j;
   TRISB = 0;
   while (1)
      PORTB = 0x00;
      Delay1KTCYx(i);
      PORTB = 0xFF;
      Delay1KTCYx(255-i);
Do you have any suggestions to make this project work? If you need any other details about my system, please feel free to ask.
Any help or guidance will be appreciated greatly.
Added after 4 hours 19 minutes:
Someone told me to add the lines
ADCON1=0x0f;   // all digital
CMCON=7;      // no comparators
before anything else in order to make ADC port bits digital (i.e.; to disable to built in ADC feature).
I did so, but it didn't change anything, the LCD screen is still blank.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
brucelee2
Helped: 1
Post08 Nov 2009 17:34
Hi there,
I was also struggling to find and implement a library for my GLCD some time ago. THe easiest that i found was 'MikroC' from Mikroelectronica.
I also had left out my 'reset' line on the GLCD too :S.
Hope this helps, They also have a serial library for it.
Cheers:D
Back to top
VSMVDD
Helped: 55
Post12 Nov 2009 16:30
your code above
the problem is simple
you have no start vector {ie system clock} set to your header
more over the main class header you intend to address this driver with
so add the right directive to add a clock
setting compilers and programmers isnt enough
you need to tell the code what its clocking is also
or the micro will wander around somewhat stupified by a lack of inner incentive
basicaly you must set a main clock define in the main header
or the lcd class will inherite the wrong timing vectors
and not run correctly and at the same 'routine times' as your main class
but at an aspect of the main class routines themselfs
and this is not correct for an lcd driver or any driver
a driver should be called while its own class is run at system clock
run and unloaded ,.. and not within vectors of a main class as it dirived routines clocking.,..
so move the clock defines to the main .h
Added after 9 minutes:
its a usefull feature
as you can use a local routine clock that takes a pin input to clock its internal routines
and then once say a scan of the pins and some sort of code is satisfied
the main clock can be used and pll etc engaged
so this is a good feature
interrupt clocks { exection time frames}
code clock {execution clock}
system clock {compiler set but code adjusted per direcitve}
main clock {external or internal low freq or high frequency pllX2.4 or not &| runtime reset}
Back to top
hkBattousai
Helped: 4
Post12 Nov 2009 21:09
I finally made it work!!
The problem was that, the library assumes that CSx bit of my LCD is complemented, but they are actually not complemented. I used two NOT gates to complement CS1 and CS2 bit of PIC output before driving LCD with them.
Now... My next aim is interfacing USB port with PIC...
Wish me luck...
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
KS0108 LCD and Assembler (3)
Which LCD KS0107/KS0108 or T6963 or ...? (2)
Need LCD command list for KS0108 (2)
can not read data from ks0108 lcd (2)
bmp to hex tool for ks0108 graphic lcd (1)
PIC C18 Library Needed for 128x64 KS0108 Graphic LCD (1)
interfaceing PIC16f84a and Siemens a57 how? (3)
Pic18f2550 and USB (2)
pic18f2550 and usb (2)
PIC18F2550 and PC Software? (4)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
