electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
what determine the supply voltage of a cmos ic chip?
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog IC Design & Layout -> what determine the supply voltage of a cmos ic chip?
Author Message
catrat
Post06 Nov 2009 2:36
hi, friends,
I was asked to help design a small mixed-mode cmos IC chip. the supply voltage of target chip is about 1.8V to 5V. I know nothing about the cmos process,only design some digital logic before. what affect the input voltage range ? the process(0.35 0.25 0.1Cool? the IO pad design? thanks a lot!
regards,
Back to top
dick_freebird
Helped: 45
Post06 Nov 2009 2:59
Gate ox and channel length and some "drain engineering"
account for transistors' working voltage. Some are hard
limits, some are negotiable against environment and reliability.
If you want a natural 5V capability without worrying, you are
probably at a 0.8um drawn gate and at least 120A Tox (if
you want reliable). You can probably find some 0.5um
range technologies where the "I/O" transistors have a thick
oxide and relaxed groundrules so you can get some latitude
in density and working voltage, section by section. By the
time you get down to 0.18um you'll be lucky to have 3.3V
as your high voltage option.
Back to top
catrat
Post07 Nov 2009 2:56
Re: what determine the supply voltage of a cmos ic chip?
thanks for the reply.
now current mcu chips on market, for example, atmel's avr series, all support a wide power supply voltage range from 1.8v to 5.5v. How does it make this? with low voltage logic and circuit inside and a wide voltage range tolerant io pad design? and it should have some voltage regulator built in?
Back to top
erikl
Helped: 138
Post07 Nov 2009 12:56
catrat wrote:
... support a wide power supply voltage range from 1.8v to 5.5v. How does it make this? with low voltage logic and circuit inside and a wide voltage range tolerant io pad design?
3 different oxide thicknesses for 3 different voltage regions (e.g. 1.8V for the digital core, 3.3V for ADC and other analog stuff, and 5V for the IOs). At least 2 additional masks per oxide thickness are needed (active_area & contacts), which means (at least) 4 more masks in the mask set in comparison to a 1-voltage-only-design. Apart from the additional mask costs and process work steps, these are "yield-critical" masks, rendering the process even more expensive because of decreasing its yield.
catrat wrote:
... and it should have some voltage regulator built in?
For sure! Sometimes the 5V IOs are only 5V-tolerant, i.e. the chip is operated with (nominal) 3.3V (or 2.5V), and the core voltage of 1.8V (or 1.2V) is generated internally.
Back to top
FvM
Helped: 766
Post07 Nov 2009 15:07
You did only consider technology dependent maximum transistor voltage. Apart from maximum voltage, there's another
important parameter: MOS threshold voltage. It can be varied in transistor design and also decides about the voltage range
and speed versus voltage of a CMOS desígn. You'll surely figure out, that it must have a certain relation to the supply
voltage for intended operation of a CMOS circuit.
Back to top
erikl
Helped: 138
Post07 Nov 2009 16:57
FvM wrote:
... must have a certain relation to the supply voltage for intended operation of a CMOS circuit.
Fortunately, Vth rises with TOX. But of course you're right: if special Vth adjustment is required, additional implants (and 2 more implant masks, for nmos & pmos) are necessary, too. (That's why I wrote "at least 2".) Wink
Back to top
catrat
Post08 Nov 2009 13:03
the chip, is about a mcu plus a op amp and voltage comparator,the power supply of the chip, is 1.8v to 5.5v, and the digital io voltage is related to the power supply, and the input of op amp is about 0 to 500mv ... and the mcu should have flash memory built in. so first of all, I should choose a process with mixed-mode and flash mem support, right? and 2nd, the process, ( .18 .25 or .35) should based on the low voltage of power supply (1.8v), right? how about running all in a low voltage inside the chip and with a on-chip voltage regulator on power supply pin?
Back to top
erikl
Helped: 138
Post08 Nov 2009 17:35
catrat wrote:
... so first of all, I should choose a process with mixed-mode and flash mem support, right?
For sure!
catrat wrote:
... and 2nd, the process, ( .18 .25 or .35) should based on the low voltage of power supply (1.8v), right?
Right. Probably a .18 process.
May be possible. But it depends also on which supply voltage the flash mem will run, and which analog building blocks for which operating voltage are already available.
Back to top
deepak242003
Helped: 10
Post09 Nov 2009 8:15
Can you elaborate your point?.
My understanding there should be only one extra mask layer ( thick oxide layer) for corresponding voltage range.. Contact and diffusion will be same.. That leads to only 2 more mask for 3 differnt voltage regions..
Please correct if I am mistaken anywhere.
Deepak.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
erikl
Helped: 138
Post09 Nov 2009 11:28
Deepak.
Hi Deepak,
may be this depends on the foundry (and on the process size) : our fab uses a special contact mask for each oxide thickness, at least for processes ≤ 0.35µm. AFAIK, the reason for this is the amount of underetching: the thicker the oxide is, the more underetching occurs. That's why the contact dimensions are prepared differently during data prep. For design, the contact dimensions are all the same, of course. And, yes: diffusion mask is the same.
Rgds, erikl
Back to top
deepak242003
Helped: 10
Post09 Nov 2009 12:49
Does it mean that, although we are using same diffusion and contact for every oxide thickness, while fabrication contact mask are different....??
Deepak.
Back to top
erikl
Helped: 138
Post09 Nov 2009 13:01
deepak242003 wrote:
Does it mean that, although we are using same diffusion and contact for every oxide thickness, fabrication contact masks are different....??
Deepak.
Exactly!
erikl
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
how to determine the value of the power supply for a chip (3)
what should be the supply voltage ?? (5)
What is the minimum supply voltage for Op-amp IC 741 (2)
determine the power supply filter capacitor value (3)
How to determine the price of a design or a System on chip? (2)
what determine the gain of VCO? (3)
How to get negative voltage supply from +DC Voltage supply (3)
The supply voltage for the portable handset ICs (1)
help needed on the standard of the supply voltage of IC (4)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
