| Author |
Message |
anandpv2009
Joined: 11 Aug 2009 Posts: 63 Helped: 4 Location: India
05 Nov 2009 14:12 PC Based oscilloscope |
I need a PC based oscilloscope circuit.It should have a bandwidth at least 1mhz.
My idea is
VOLTAGE TO FREQ.CONVERTER IC ------>PIC18F2550/4550----->PC----->SOFTWARE
I am willing to write software for oscilloscope in PC but I have no enough knowledge to design the circuit.I am planning to use HID communication to interface PIC with PC
Any idea.... Please post your idea because i need a scope but i don't like to spend more money to buy one...
Thanks.....
| Back to top |
betwixt
Joined: 04 Jul 2009 Posts: 383 Helped: 62 Location: Wales, UK
05 Nov 2009 14:50 Re: PC Based oscilloscope |
That *might* work but I doubt you would see any advantage over simply measuring the voltage with the on-board ADC.
The problem:
To measure DC up to 1MHz your V to F converter will have to run at a much higher frequency and have a linear conversion factor. The PIC can measure frequencies but not if they are very high, the resolution will not be good. Also consider that trying to accurately and continuously measure frequency may be difficult while also handling USB transfers.
Brian.
| Back to top |
anandpv2009
05 Nov 2009 16:18 Re: PC Based oscilloscope |
I think it is possible if V to F conversion is possible.
Any one can suggest a circuit that converts Voltage to Freq. (1mhz bandwidth)
Thanks[/code]
| Back to top |
nandhu015
Joined: 11 Feb 2006 Posts: 640 Helped: 46 Location: Tamilnadu, India
06 Nov 2009 15:12 PC Based oscilloscope |
hai anand
Have you searched the net?
There are some nice completed projects on the net
this is one of them
http://www.semifluid.com/?p=24
search the net you will find more
Nandhu
| Back to top |
Google AdSense
06 Nov 2009 15:12 Ads |
| Back to top |
Jack// ani
06 Nov 2009 19:21 Re: PC Based oscilloscope |
| nandhu015 wrote: |
this is one of them
Nice one, very resourceful link.
Thanks for sharing with us.
| Back to top |
dian
Joined: 16 Apr 2006 Posts: 41 Helped: 7 Location: Indonesia
07 Nov 2009 14:04 PC Based oscilloscope |
| i agree with betwixt why dont you direct convert the volatge with ADC? Every conversion step will reduce the accuracy, would you explain why you need to convert the V to F first?
| Back to top |
anandpv2009
07 Nov 2009 16:29 Re: PC Based oscilloscope |
| Amplitude of voltage to the PIC A/D input is limited that is why I suggested V to F ICs. I recently saw a EFY magazine (not new) with constructional details + schem. of microcontroller based oscilloscope.
| Back to top |
betwixt
07 Nov 2009 19:52 Re: PC Based oscilloscope |
Measuring in the voltage domain is quite easy although achieving 1MHz bandwidth without using special hardware could be a problem. The internal ADC in a PIC isn't fast enough to sample at 2MHz (the absolute minimum rate to see 1MHz signals).
If you convert to frequency, the measurement becomes far more difficult. To be able to measure a frequency which is modulated at 1MHz, it has to be at least (Nyquist limit) 2MHz at it's lowest and a PIC will struggle to measure such short cycles accurately. If you increase the frequency to improve resolution, you decrease the ability to measure it accurately. Even if you could measure it, at such high frequency deviation it would be very difficult to keep the frequency increase linear to the voltage.
You might be able to sample fast enough if you use two or more PICs with the ADC triggering alternating between them but keeping them in sync would be difficult.
Brian.
| Back to top |
anandpv2009
07 Nov 2009 20:20 Re: PC Based oscilloscope |
I think it is not easy to synchronize two or more PICs. But i will try to do....
If any ideas please post it.
| Back to top |
