electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Junction Capacitances of Transistor at RF Frequencies
Post new topic  Reply to topic    EDAboard.com Forum Index -> RF, Microwave, Antennas and Optics -> Junction Capacitances of Transistor at RF Frequencies
Author Message
WTech
Post05 Nov 2009 6:29
I am stuck in designing amplifier circuit using BJT at 1GHz. I need to calculate its junction capacitances at above frequency and biasing point selected by me, using given in datasheet.
can any body help me
Thanks
Back to top
Abhishekabs
Helped: 84
Post05 Nov 2009 6:40
Why you are calculating junction capacitances??
You get everything in datasheet required to design an amplifier, if it is not sufficient then contact manufacturer for more data.
Back to top
WTech
Post05 Nov 2009 6:49
Re: Junction Capacitances of Transistor at RF Frequencies
data sheet only contain capacitance at specific junction voltage and specified frequency, and it changes with respect to voltage and frequency. so i need to know how can i calculate it, using given capacitance in datasheet at my own frequency and junction voltages.
Back to top
Abhishekabs
Helped: 84
Post05 Nov 2009 7:04
You need to serach for equeations in books relatated to microwave transistors.
also see books such as solid state devices by Ben G Streetman.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
timof
Helped: 6
Post15 Nov 2009 9:05
There is no simple formula for voltage dependence of capacitance for arbitrary (i.e. arbitrary doping profile) p-n junction. There are analytical formulas for p-n junctions with constant doping profiles and for linearly graded profiles, but real p-n junctions may show a difference voltage behavior. (as an example, for p-n junction with constant doping profile, capacitance scales as C~1/sqrt(V-Vbi) with voltage V (Vbi is built-in voltage for p-n junction).
The "intrinsic" capacitance of p-n junction (that is, the capacitance of the depleted region) is independent of frequency, assuming an instantaneous response of the quasi-neutral regions to applied voltages. In reality, if doping (or conductivity) of the quasi-neutral regions is not high enough, the effective capacitance becomes frequency dependent, as there is a series resistance (of the quasi-neutral regions) in series with the "intrinsic" capacitance - so you get an RC effects and associated frequency dispersion of capacitance. If current flow in p-n junction (in quasi-neutral regions) is lateral , i.e. parallel to the plane of the p-n junction, you may need to consider a distributed RC network/model.
Max
Back to top
FvM
Helped: 767
Post15 Nov 2009 11:55
You are misunderstanding the datasheet, I think. Usually capacitances are specified with a measuring frequency (1 MHz)
and a voltage. Additionally, most datasheets also have a diagram of the voltage depency. If not present, you can assume the
voltage depency to be similar to other transistors of same technology, that have this data.
But what does the 1 MHz mean? In my opinion, it's simply a sufficient low frequency to observe a pure capacitance.
The capacitance is almost frequency independant, but at higher frequencies, it doesn't appear as a pure capacitance, you have to use
e.g. S-parameters to describe the transistor impedances. At 1 GHz, also package impedances, particularly inductances play
an important role, they are also considered with S-parameters. Either you have S-parameter tables from the manufacturer, or
you can try a SPICE simulation, but it's only meaningful with a correct package model.
Back to top
VSWR
Helped: 72
Post15 Nov 2009 15:07
Which transistor are you using (designation, manufacturer)?
Thanks
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
bipolar junction transistor (13)
Cje Transistor Junction Capacitor (1)
Bipolar junction transistor question (7)
low frequencies vs high frequencies (8)
CMOS capacitances (2)
DIODE CAPACITANCES (1)
Negative Capacitances by Cadence (4)
Low henry capacitances? (9)
A question about MOS capacitances (8)
Cadence- parasitic capacitances problem (2)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
