electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
12vdc to 220vac inverter with pic 16f873
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> 12vdc to 220vac inverter with pic 16f873
Author Message
spocky
Post04 Nov 2009 17:46
Hi! I am an amateur user of pic microcontrollers and I want to make a pure sine inverter 12v to 220v 50Hz and the output will be 200-300W. I must use pic16f873.Could someone help me with a schematic of the circuit I want to make please???Sorry for my english....
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
saeed_pk
Helped: 5
Post05 Nov 2009 17:30
There are two methods for doin this
-- invert 12VDC to 12VAC then use a step up transformer
-- use a converter to raise the voltage upto 300VDC then invert
which one you want to use
Back to top
spocky
Post05 Nov 2009 22:39
the first method you said uses pic m/c?Do you have any schematic?
Added after 36 minutes:
My teacher also told me if I could make an inverter without transformer?He also told me that using PWM of pic16fxx I could make a sine Voltage using a lot of square pulses.
Back to top
betwixt
Helped: 64
Post06 Nov 2009 10:47
Re: 12vdc to 220vac inverter with pic 16f873
It's true that using PWM or a DAC you can make almost any waveform but have you consider that the maximum voltage you can produce from a 16F877 is 5V and without other circuitry, the maximum power it can produce is less than 1 Watt.
You don't have many options and none are very efficient unless you use a transformer:
Generate a square wave (you don't really need a PIC for that) at 12V and feed it to a voltage multiplier to step it up using a diode multiplier. Then take the output from a H-bridge configuration to allow the polarity to be reversed. You will have to use diodes with very low forward voltage drop at >20A forward current and they are hard to find. You may be able to find a Germanium type that can do it, good luck trying.
There are variations on that theme but all have the same problem of generating enough voltage. The idea of using a transformer is that you convert the power from low voltage to high voltage by converting high current to low current. I can't think of any other way of doing it efficiently at 300W load. Using the method I mentioned earlier, I expect efficiency to be less than 10% if it worked at all.
Brian.
Back to top
spocky
Post06 Nov 2009 13:22
Ok I can't find either informations without transformer.Is there any inverter circuit with schematic using any pic of 16f series with pwm method (with transformer)?
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
12VDC / 220VAC 100Watt inverter (21)
12vdc-220vac 100/200watts sinewave inverter (15)
12vdc-220vac 3kva inverter circuit diagram. (2)
12Vdc to 220Vac 3000W Inverter Full Schematics And Pcb (5)
Can make a 12VDC-220AC inverter 300W with 4$ ? (1)
Need Help with building an inverter from 12vdc to 110vac.... (2)
unlocking pic 16f873 (8)
ups from 12 volts vdc to 220vac - inverter 500watts (1)
12vdc - 240vac power Inverter (13)
12VDC to 127VAC inverter using LM3524 (9)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
