electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Off delay Timer without battery
Post new topic  Reply to topic    EDAboard.com Forum Index -> Hobby Circuits and Small Projects Problems -> Off delay Timer without battery
Author Message
vicky.pace
Post04 Nov 2009 11:54
Off delay Timer
Dear All,
I want to make a OFF DELAY TIMER which switch over after power goes. It works with power stored inside the circuit and switches relay after set time i.e. 0-60 sec.
There will not be any battery inside.
Please suggest.
Regards
Vicky
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
pranam77
Helped: 94
Post04 Nov 2009 13:49
Re: Off delay Timer
vicky.pace wrote:
Dear All, I want to make a OFF DELAY TIMER which switch over after power goes. It works with power stored inside the circuit and switches relay after set time i.e. 0-60 sec. There will not be any battery inside. Please suggest. Regards Vicky
Without a battery inside, how can you switch a load like relay during power failure? even Super Caps cannot power such loads. I think a battery is mandatory. Cheers
Back to top
FvM
Helped: 767
Post04 Nov 2009 14:46
To make the relay specification understandable, you should tell what's actually switched by it. With out any power source,
nothing can be switched, even if the relay has a suitable backup power.
Back to top
nandhu015
Helped: 46
Post04 Nov 2009 15:19
Try using supercapacitor
A little info about supercapacitor
http://www.batteryuniversity.com/partone-8.htm
Back to top
vicky.pace
Post04 Nov 2009 16:43
Re: Off delay Timer without battery
In fact we may use A latching relay for this.
Vicky
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
Delay off timer (1)
power off delay- need help to use timer for specified use (1)
1 minute on, 3minute off 555 timer (1)
Req. Telephone Cut Off Timer cir? (4)
timer with 45seconds ON and 4 minutes off.... (1)
My periodic ON-OFF timer don't work. They are two CD4541. (1)
Need 555 timer to start when power is turned off, sort of... (6)
Reference about LDO without any off-chip compensation (7)
Mobile without battery (4)
delay off (1)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
