electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Voltage Amplifier at 1MHz, 40dB
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> Voltage Amplifier at 1MHz, 40dB
Author Message
aviaden
Post04 Nov 2009 10:09
Voltage Amplifier
I need help in designing a voltage amplifier. My input signal is a few mili volts, around 1 MHz, and i need a gain of at least 40db.
I tried some circuits but nothing worked well...
I will Appreciate any help....circuits, PSpice files or any other ideas...
Thanks, Aviad.
Back to top
electrik1
Post04 Nov 2009 11:47
Re: Voltage Amplifier
check the Gain Bandwidth product of your opamp(in the datasheet). not every opamp can give you 40db at 1 MHz. you are going to need a very high frequency opamp.
Back to top
aviaden
Post04 Nov 2009 15:25
Re: Voltage Amplifier at 1MHz, 40dB
Thanks for the answer.
Actually i'm using a high freq opamp- AD8042, in "clasic" non inverting circuit.
Any other ideas?
Back to top
LvW
Helped: 242
Post04 Nov 2009 15:47
As the AD8042 has a gain of app. 40 dB at 1 MHz, this is not sufficient for a closed loop gain of app. 40 dB.
Try to use an opamp which has at least 500 MHz GBW. This opamp needs not to be compensated. What about a current feedback amp ?
Back to top
aviaden
Post04 Nov 2009 16:09
Thank's for the reply.
1) Are you femilier with such a opamp? With a BW of 500 MHz?
2) Can you send me a link/ add a scheme/ describe this kind of current feedback amplifier circuit?
Thank's, Aviad.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
LvW
Helped: 242
Post04 Nov 2009 18:58
There are many opamps resp. current-feedback amps (CFA) which have high frequency capability; for example the AD8001 has a unity gain frequency of app. 800 MHz.
This is a CFA which can be used like a non-inverting opamp circuit - provided you select the feedback resistor as recommended by the mnufacturer (data sheet).
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
About RF amplifier (tested at 1MHz) (1)
MGA-81563 0.1MHz - 6GHz amplifier (2)
Infinite VSWR tolerant power amplifier for 0.1-1MHz (2)
why opamp is called voltage controlled voltage amplifier? (4)
Can a voltage divider act like a voltage amplifier? (15)
A question about the isolation of a 40db coupler.Help!!!!~ (2)
A question about the isolation of a 40db coupler.Help!!!!~ (6)
Power Amplifier vs Voltage Amplifier (14)
voltage amplifier (10)
Voltage amplifier ... (2)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
