electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Wilkinson divider power distribution
Post new topic  Reply to topic    EDAboard.com Forum Index -> RF, Microwave, Antennas and Optics -> Wilkinson divider power distribution
Author Message
ieok
Post04 Nov 2009 5:04
For a Wilkinson divider, what would happens on power distribution if port3 is open circuit o/c and port2 is matched. (port1 is input port).
All power delivered to port3 will be reflected, and half of it deliver to port1.
Could someone explain in detail?
Back to top
vfone
Helped: 327
Post04 Nov 2009 8:25
Re: Wilkinson divider power distribution
If you do this and if the power is relative high, first of all the internal 100 ohms resistor will burn out.
Back to top
ieok
Post05 Nov 2009 5:44
any other detail explanation beside that?
Back to top
jayleung
Post05 Nov 2009 7:01
Just a simple simulations for the above situation, it gets:
S11=-6dB (25%)
S21=-3dB (50%)
It means that if the resistor is working, half of the input power from port 1 goes to port 2, 25% of the input power reflected back to port 1.
Where is the rest of the 25%? Because wilkinson power divider actually is not pure lossless, the 100 Ohm resistor consumes the rest 25% power.
Here is the interesting point:
When port 2 and port 3 are both 50 Ohm, the potentials across the 100 Ohm resistor leads are the same, so in this case the wilkinson power divider is lossless if input power from port 1.
However, when port 3 fails, goes to open or short, the potentials over 100 Ohm resistor are no longer the same, so current would flow across it, and the power would become heat.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
ieok
Post05 Nov 2009 7:49
thank you.
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
Wilkinson Power Divider (2)
Wilkinson Power Divider (3)
wilkinson power divider? (3)
Wilkinson power divider (2)
wilkinson power divider (1)
wilkinson power divider, (2)
Wilkinson Power Divider (10)
miniaturized Wilkinson power divider (6)
Wilkinson Power Divider Design (11)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
