electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Can I design a typical bandgap voltage reference with NPN?
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> Can I design a typical bandgap voltage reference with NPN?
Author Message
kkilambi
Post04 Nov 2009 1:34
Can I use an NPN transistor for a Bandgap voltage reference.
I have used it just by inverting the circuit by connecting the NPN transitors to the power supply.
I am getting good nearly temperature independent bandgap voltage at 3.3 V.
But the voltage drops wit power supply naturally.
As I am simulating it for minimum and maximum cases of power supply it is changing proportionally with power supply. How do I deal with?
Thank you.
Back to top
Google
AdSense
Google Adsense
Ads
Sorry, but you need login in to view this attachment
Back to top
saro_k_82
Helped: 55
Post05 Nov 2009 12:12
Re: Can I design a typical bandgap voltage reference with NP
I'm not sure that your process has the luxury of NPN but not the substrate PNPs.
Coming to the schematic, your reference is referred to the supply instead of ground.
If you use the PTAT current and generate the reference wrt ground you wont see huge supply dependence.
Back to top
dick_freebird
Helped: 45
Post05 Nov 2009 16:07
When I was working in bipolar technologies, we used
nothing but NPNs for the reference elements. You pick
the best from what's in the basket you are given.
Back to top
lyc1981
Post07 Nov 2009 12:49
NPN can be used in deep Nwell process. So you need check your process.
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
help design bandgap voltage reference circuit. (6)
how to design a practical bandgap voltage reference ? (10)
How to design a bandgap voltage reference? (basic) (8)
How to design voltage detector without bandgap reference? (6)
About bandgap reference and voltage reference circuit? (15)
how can i generate 2.5Volt output voltage with BandGap? (7)
bandgap voltage reference (22)
about bandgap voltage reference (7)
Bandgap voltage reference circuit (1)
Bandgap reference ( output voltage variation) (18)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
