electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
RF amplifier - design suggestion
Post new topic  Reply to topic    EDAboard.com Forum Index -> RF, Microwave, Antennas and Optics -> RF amplifier - design suggestion
Author Message
yawijaya
Post03 Nov 2009 22:02
Hi all,
I am designing a RF amplifier. I would like to get some suggestion input about what type i should use and possibly design reference. Here's the requirement:
1. output power 2W to 50 ohms load
2. Frequency range 50MHz-120MHz
3. Low 2nd harmonic
4. high efficiency
I made one before but the efficiency was only 20 percent or so using class E RF amplifier. SO i'm now open to any suggestion.
Thanks!!!
Back to top
vfone
Helped: 327
Post04 Nov 2009 8:22
Re: RF amplifier - design suggestion
You didn't specify the power class of the amplifier, or at least the modulation type of the amplified signal.
Back to top
yawijaya
Post04 Nov 2009 14:36
well, that's basically what my question was. I am looking for suggestion on what power class i should use. I've tried class E before, but they are only good between 50M-70Mhz.
Back to top
vfone
Helped: 327
Post04 Nov 2009 16:33
The best efficiency power class is Class C, but this class is very nonlinear and can be used only for CW or FM.
Class AB is pretty linear. On this power class tuning the bias point and load-pull the output match can get minimum of the harmonics and best efficiency.
Back to top
rezaee
Helped: 1
Post04 Nov 2009 22:02
if u want high efficiency then u must select switching mode amplifier same class E OR F OR D. which u want to design? amplifier or power amplifier?
which class E circuit topology you use for your designing? do you simulate your schemitic or no?
Back to top
yawijaya
Post04 Nov 2009 22:14
I've designed it using HEPA PLUS (class E power amp software) which simulates the schematic and worked very well ~70% efficiency, but the circuit sucked in reality. I am designing power amplifier. I also forgot to mention that the circuit needs to be able to give up to 200-300mA output current (aside form the 2W at 50ohm load)
Back to top
rezaee
Helped: 1
Post04 Nov 2009 22:31
with which type of elements you simulate your designed circuit in HEPA PLUS?? i means is you use ideal elements or use realistic elements model?
also i am trying to design a class E power amplifier but i use ADS software ofcourse my design is for IC i think if you use realistic model for simulation your result dont be very differ.
which topology you use for your fully circiut schematic?
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
yawijaya
Post04 Nov 2009 22:43
it was realistic elements model...
Back to top
rezaee
Helped: 1
Post04 Nov 2009 22:45
Hmmm... 70% to 20% !
which class E circuit topology you use?
Back to top
yawijaya
Post04 Nov 2009 23:04
i'm not sure by what you mean with topology...but here's the schematic...
Sorry, but you need login in to view this attachment
Back to top
rezaee
Helped: 1
Post04 Nov 2009 23:56
i see your schematic diagram of course somethings isnt clear in your designed circuit schematic but i think its better to use matched circuit instead of transformer and also use match filter between deriver stage and amplifier stage and check your elements values with using good fitting analytical equations and also notice the breakdown voltage of your transistor and the other way is to check your circuit point to point with scope for example do you see desired output at the adc(square wave)....
Back to top
vfone
Helped: 327
Post05 Nov 2009 7:04
Class E is hard for practical implementation for someone with no experience.
Class AB it will work right away, allowing a lot of tuning of initial design.
Now depends what you are looking for. To learn, or to get quickly a final product.
Back to top
FvM
Helped: 767
Post05 Nov 2009 8:09
Your results simply show the limitations of designing a RF amplifier by just using a software. Assuming, that the said circuit
simulation is correct so far, some real circuit parameter is obviously different. But which one? Experience is needed to identify
it and only empirical measurements can verify the design.
Back to top
yawijaya
Post05 Nov 2009 14:41
Ha, well, ideally i want to learn and get a final product quickly...but i guess i have to choose one of them...I guess i'll lean toward quick final product...so you say class AB?
but i also read before that class AB does not perform well for low signal application...
Back to top
vfone
Helped: 327
Post05 Nov 2009 16:46
Surprisingly Class-AB offers wider dynamic range than any other power class, including Class-A. This because saturation comes from different additional sources.
In Class-AB tuning the bias point (quiescent) for optimum conduction angle leads to better efficiency and linearity.
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
Car power amplifier suggestion (4)
Need any suggestion on RF amplifier IC (4)
Suggestion of amplifier IC for making 5.1 channel Amp (23)
suggestion on IC front-end design (31)
OTA design book suggestion (3)
Need suggestion on RF system design books (7)
Give me some suggestion about antenna design,pls (5)
some suggestion on antenna design inside a metal housing (2)
ADF4360-8 PLL - need suggestion to design loop filter (3)
Any suggestion for good PLL CIRCUIT design book ????? (7)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
