electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
damaged lead acid batteries in UPS systems-advice needed
Post new topic  Reply to topic    EDAboard.com Forum Index -> Electronic Elementary Questions -> damaged lead acid batteries in UPS systems-advice needed
Author Message
calling
Post03 Nov 2009 16:45
UPS battery damaged
I have a UPS system which uses sealed lead acid batteries 12V 100Ah.
All the batteries are damaged and I can't understand why. They all have lead sulfate in the negative terminal.
Can anyone explain me why did this happened?
Thank you.
Back to top
Audioguru
Helped: 95
Post03 Nov 2009 22:10
UPS battery damaged
A lead acid battery gets sulphated if it sits uncharged for a few months. It will self-discharge by itself in a few months without being charged.
Maybe the charger is broken.
Back to top
pranam77
Helped: 94
Post04 Nov 2009 7:48
UPS battery damaged
Battery's get damaged probably due to over charging , or insufficient charging, or passage of time. You didnt mention how old are the battery's. Cheers
Back to top
calling
Post04 Nov 2009 9:54
Re: UPS battery damaged
The batteries are about 1/2 year old I think.
What I think that is strange is the fact that all the batteries have the same problem. The protection around the negative terminal burst and the mixture of lead sulfate with sulfuric acid got off the batteries.
Back to top
rajudp
Helped: 10
Post04 Nov 2009 13:06
UPS battery damaged - lead sulfate in the negative terminal
for 6 months you will get warranty
Back to top
pranam77
Helped: 94
Post04 Nov 2009 13:43
No...naturally the said problem is not a manufacturing defect to claim a warantee.
calling wrote:
The batteries are about 1/2 year old I think. What I think that is strange is the fact that all the batteries have the same problem. The protection around the negative terminal burst and the mixture of lead sulfate with sulfuric acid got off the batteries.
Check out what is the output voltage of the charger. Also let me know what load is driven by the batteries? And too confirm that the vent plugs of all cells are well ventilated to emit the gasses. Cheers
Back to top
calling
Post04 Nov 2009 14:57
The batteries are sealed so I think they do not release the gasses (correct me if I'm wrong). I can't do the measures you're asking =(. I just need know what are the possible causes of the problem but as I don't understand a lot of batteries I came here to see if someone could help me.
For what you've said the possible causes of this problem can be excess of voltage in the output of the charger or overload? Couldn't it be a manufacturing defect or is it normal that the protection around the negative terminal burnt.
Can you also explain me why did it happened only in the negative terminal and not on the positive too? Cheers
Back to top
pranam77
Helped: 94
Post04 Nov 2009 15:42
Every battery when charged, releases toxic gasses. If the battery is a sealed one, there will be small vents through which the gases escape.
calling wrote:
Couldn't it be a manufacturing defect or is it normal that the protection around the negative terminal burs..
It is not normal to get a terminal burnt off. You may contact the supplier to see wether he honours the warantee for the same and also you may get better solution from him for the problem.
Without measuring i coudnt figure out whatz the prolem. I am sorry...may be you'll get some better answers.
Back to top
Audioguru
Helped: 95
Post04 Nov 2009 16:14
UPS battery damaged
First the batteries were suphated which happen when a lead-acid battery sits for months without a charge.
Now the problem is completely different: the "protection" burst and the negative terminal is burnt. The batteries are now leaking sulphate and acid?
Back to top
calling
Post04 Nov 2009 16:37
They are leaking a white paste which I think is a mixture of lead sulphate and acid. But only from the negative terminal (all of them).
Back to top
Audioguru
Helped: 95
Post04 Nov 2009 16:54
UPS battery damaged
Lead sulphate is a material that is deposited on the lead plates of an old battery. It is not a paste.
I think the white paste is the electrolyte gel in a sealed gel-cell battery. The battery is completely sealed and normally does not produce gas.
I think the UPS over-charged the batteries which caused gas which exploded the sealed case around the negative terminals.
A gel-cell battery is supposed to be charged to a lower voltage than a wet-cell battery. If you replaced wet-cell batteries with gel-cell batteries then you are to blame for the damage.
If the UPS is also only 6 months old then the UPS manufacturer should fix the charger in the UPS and should replace the damaged batteries.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
calling
Post05 Nov 2009 9:34
So you think the problem is on the charger and not on the battery?
Couldn't it be a manufacturing problem? For example a weak sealed case around the negative terminal?
And why do you think it happened only on the negative terminal? Cheers
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
Lead acid batteries (7)
Information about charging Lead-Acid Batteries (1)
Battery charger for lead acid batteries. (3)
sealed lead acid and car batteries (6)
GEL vs. valve regulated lead Acid Maintenance free batteries (1)
replacing UPS sealed LeadAcid battery with CAR LEAD ACID???? (6)
sulpheoric acid for batteries (5)
PC UPS maintenance advice needed, for better battery life. (2)
Lead-Acid charger (18)
lead acid charger (27)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
