| Author |
Message |
innovation1
01 Nov 2009 15:44 AN INDUCTOR |
| HI.......... A CAPACITOR PASSES AC N BLOCKS DC..... SAME WAY OR ANY OTHER WAY WHT DOES AN INDUCTOR DO??????????????
| Back to top |
flatulent
Joined: 19 Jul 2002 Posts: 4877 Helped: 324 Location: Middle Earth
01 Nov 2009 16:13 Re: AN INDUCTOR |
| The inductor passes DC and blocks AC if its value is high enough.
| Back to top |
haker_fox
Joined: 24 Jun 2009 Posts: 51 Helped: 4 Location: Russia, Irkutsk
02 Nov 2009 2:28 Re: AN INDUCTOR |
| innovation1 wrote: |
| HI.......... A CAPACITOR PASSES AC N BLOCKS DC..... SAME WAY OR ANY OTHER WAY WHT DOES AN INDUCTOR DO?????????????? |
The inductor resistance is X = w * L, where w - angular frequency (rad/s) and L - inductance (H).
| Back to top |
micard
Joined: 14 Oct 2009 Posts: 21 Helped: 1 Location: Maastricht
02 Nov 2009 13:09 Re: AN INDUCTOR |
| haker_fox wrote: |
The inductor resistance is X = w * L. |
The reactance not resistance!
Impedance is an complex number Z where:
Z=R+jX
R - resistance
X - reactance
| Back to top |
Kazzam
02 Nov 2009 13:29 Re: BEHAVIOUR OF AN INDUCTOR vs CAPACITOR |
| it stores energy for a longer period of time created by passing electric current through the inductor........
| Back to top |
Google AdSense
02 Nov 2009 13:29 Ads |
| Back to top |
innovation1
02 Nov 2009 15:37 Re: BEHAVIOUR OF AN INDUCTOR vs CAPACITOR |
| inductor stores energy..... so can it be used as a source to drive a circuit....
| Back to top |
Kral
02 Nov 2009 17:28 Re: BEHAVIOUR OF AN INDUCTOR vs CAPACITOR |
innovation1,
The difference can be explained from the fundamental equations.
For an inductor, v = Ldi/dt, Where V is the voltage across the inductior, L is the inductance, di/dt is the rate of change of current thru the inductor. For high frequencies, di/dt is a high value, therefore the voltage across the inductor is high. For DC, di/dt is zero, therefore the voltage across the inductor is zero.
For a capacitor, i = C dv/dt, where i is the current thru the capacitor, C is the capacitance, dv/dt is the rate of change of voltage across the capacitor. For DC, dv/dt is zero. Therefore the current through the capacitor is zero.
Regards,
Kral
| Back to top |
haker_fox
03 Nov 2009 1:21 Re: AN INDUCTOR |
| micard wrote: |
| haker_fox wrote: |
Z=R+jX
R - resistance
X - reactance |
I just did want to explain how AC passes through the inductor. Of course I had to write "reactance". It's my mistake. Sorry!
| Back to top |
vipinsaini
07 Nov 2009 8:45 Re: BEHAVIOUR OF AN INDUCTOR vs CAPACITOR |
For C:
X=1/W*C
W-->Angular Frequency
Where W=2*Pi*f*C
Condition (1)When we are applying AC
then for AC f=50Hz(india)
i.e.there will be some reactance
so Capacitor will pass the AC.
Condition(2)When we are applying DC
then for DC f=0(zero)
so the X will become infinite that's why due to so much high reactance the current will not flow through the CAPACITOR.
It means that CAPACITOR will block the DC Current.
[b]For L:
X=W*L
W-Angular frequency
where W=2*Pi*f*L
condition(1)When we apply DC to the inductor
then for AC f=0Hz
so the reactance will become zero that's why inductor will provide a smooth path to the DC Current.
Condition(2)When we are applying AC
i.e.there is reactance which will be more than the reactance(incase of DC).
So Inductor can't pass the AC Current.
It's the main basic for L & C.
| Back to top |
