electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Constant current led driving
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> Constant current led driving
Author Message
theasus
Post30 Oct 2009 15:12
I want to use IR led and photodiode in my project as a sensor. And for stable working I have to assure constant current for IR Led.How can i do this operation?Could you post a simple circuit and its usage?
Back to top
Naveed Ahmed
Post30 Oct 2009 16:00
Re: Constant current led driving
You can use a transistor biased circuit to make the current constant as required. Below is the link follow it and click on "Shunt Constant Current Source"
http://www.discovercircuits.com/C/constant.htm
Regards
Naveed Khowaja
Back to top
theasus
Post01 Nov 2009 14:38
Could you propose more sensitive circuit ?
I think this is not a sensitive.And this one more sensitive but i couldn't calculate the compenent values(transistor,resistor..)
Could you help about this circuit?And also for this operation we can prefer fet to transistor.But as i said i didn't calculate the right value for one led driving.
Back to top
dick_freebird
Helped: 46
Post02 Nov 2009 1:47
How constant does it really have to be? With a high enough
and tight enough voltage supply, the diode forward variation
can be small relative to headroom and a resistor will be fine.
So how good, and why?
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
theasus
Post02 Nov 2009 18:18
I want to use an IR led for a sensor application.And for this application IR led's current must be constant for stable working. And I think,to end of my voltage regulation circuit which is consists of 7805, connecting a constant current source for IR led is neccessary. And My problem is searching a good circuit for this operation.
Back to top
kender
Helped: 88
Location: Stanford, SF Bay Peninsula, California, Earth, Solar System, Milky Way
Post02 Nov 2009 20:30
How much current do you need to run through your LED?
Back to top
theasus
Post03 Nov 2009 19:55
18 mA
Back to top
kender
Helped: 88
Post04 Nov 2009 2:40
18mA is a relatively small current. An output of common OpAmp can source or sink 18mA.
Here's an example of an OpAmp constant current source: http://www.faqs.org/docs/electric/Semi/03039.png. This is just one of many topologies. LED can be hooked up instead of a load resistor.
Here's a small collection of OpAmp current source and sink circuits: http://www.maxim-ic.com/appnotes.cfm/an_pk/3869
- Nick
Back to top
vistapoint
Helped: 2
Post04 Nov 2009 15:17
This is how you calculate:
The input+ has a voltage set by the zener diode=Vz. Input- = Input+ due to feedback. So Vsense=Vz. The current through the resistors=Vz/Rsense
This is a good current sink, better than other designs in this thread.
__________________________________________
Low-price resistors, capacitor, and LEDs: http://store.engeecorp.com
Added after 2 minutes:
or current source, depending where you put the load
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
LED PWM + BUCK with constant current (18)
Why led need the constant current (1)
If you have constant current, how to get a constant Gm (1)
Constant Voltage/Constant Current Circuit? (7)
CONSTANT VOLATGE CONSTANT CURRENT circuit (4)
driving power led (4)
constant current constant voltage (3)
Driving a LED with at89c2051 (3)
Driving an LED Backlight for a LCD (3)
bjt led driving configuration differences (5)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
