electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Why is SIMO BER performance is better than MISO?
Post new topic  Reply to topic    EDAboard.com Forum Index -> Digital communication -> Why is SIMO BER performance is better than MISO?
Author Message
bee
Helped: 2
Post29 Oct 2009 19:52
tx
Back to top
saeddawoud
Helped: 3
Post29 Oct 2009 20:16
Re: Why is SIMO BER performance is better than MISO?
tx
Because in MISO system the transmitted power is divided among all transmit antennas. Usually space-time codes are used to over come this problem.
Back to top
bee
Helped: 2
Post29 Oct 2009 22:44
thanks for your reply. But how does the space-time codes help to over come this issue?
Back to top
saeddawoud
Helped: 3
Post29 Oct 2009 22:51
Actually, I don't have the details, but space-time coding is essentially channel coding and transmit diversity, where the codes are spread in space and in time, i.e.: 2-D code. So, you may expect additional gain from this process.
Back to top
mohamed_bakr
Helped: 1
Post04 Nov 2009 16:52
Actually,
Increasing receiving antennas provide diversity gain which benefits in decreasing the BER Curve slope. However, space time codes which needs the use of more than one Transmitting antenna provide shifting BER Curve to left which also, can be considered as a benefit.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
lequangvu710
Post06 Nov 2009 18:37
MISO use multiple transmit antenna, it provides full diversity gain. Example, Space time block codes, with Alamouti scheme - 2 transmit antenna and n receive antenna.
MISO's better than SIMO!
Back to top
saeddawoud
Helped: 3
Post06 Nov 2009 19:03
lequangvu710 wrote:
...MISO's better than SIMO!
Why is that? Explain to us please?
Back to top
lequangvu710
Post07 Nov 2009 8:30
What is MISO and SIMO?
MISO: Multiple input and single output, it's mean multiple transmit antennas and single receive antenna.
SIMO: Single input and multiple output, it's mean single transmit antenna and multiple receive antennas.
You know, Space - Time Coding is a type of code to increase the channel capacity or provide the diversity gain, which we want to use, we must have at least 2 transmit antennas.
With 1 transmit antenna we can't use space-time coding for the channel.
So, I really believe that MISO system is better than SIMO system!
Added after 5 hours 42 minutes:
My opinion is only right in case of using Space-time coding! ^^.
Back to top
saeddawoud
Helped: 3
Post07 Nov 2009 12:17
As I know, transmit diversity with space time coding has the same performance as recieve diversity, in terms of diversity gain, i.e.: the slope of BER vs. SNR. Now if you talk about the possibility of increasing the capacity of the channel in transmit diversity, by using spatial multiplexing, this is a different story.
Regards
Back to top
lequangvu710
Post07 Nov 2009 12:36
You was right!
But in this case, you should know:
- I just said about SIMO and MISO!
- I introduced about STC.
You didn't understand, so I think you should read what I said clearly!
If we use STC, certainly SIMO can not be used.
Back to top
saeddawoud
Helped: 3
Post07 Nov 2009 15:15
lequangvu710 wrote:
You was right!
Dear lequangvu710,
I didn't misunderstand you, all what I wanted to say is that, STC used in transmit diversity to recover the average SNR loss, compared to a system with recieve diversity. The loss will be 10\,log_{10}L_t, where L_t is the number of transmit antnnas, because the transmitted power is divided among the transmit antennas.
Regards
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
Comparing SISO and MISO BER? (1)
why 16877 better than 1684 (8)
Why is PIC better than AVR? (22)
Why PSK is better than FSK? (6)
Why is CRC better than just checksum? (3)
WHY IS DWT IN OFDM IS BETTER THAN FFT ?? (9)
why MIMO better in multipath fading than in LOS?? (2)
why sound quality in GSM is better than CDMA? (3)
Why FET works better as an RF amp than BJT? (5)
Why NMOS has better matching properties than PMOS? (11)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
