electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
about MIM capacitor problem
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> about MIM capacitor problem
Author Message
lhlbluesky
Post29 Oct 2009 13:36
i use tower 0.18um 4LM technology for my circuit design,has anyone used this technology ever before?
here, i have a question: for MIM capacitor (cmim_hc), its positive polarity uses TOP_M(the highest level metal) , M3, M2, and negetive polarity uses M3, M2, if i design a sc amplifier with single-ended output, the Cs and Cf must match well, for ex: Cs=8C0, Cf=C0, then, Av = 1 + Cs/Cf =9, in layout design, i use a cap array of 5x5, with unit capacitor C0, the inner 3x3 array for Cs and Cf, the outer 16 C0 for dummy cap, but now, by calibre PEX layout postsimulation, i find that, the parasitic cap of both positive and negetive polarity is very large, for C0=500fF, parasitic cap can have 150fF or so, then, Av = 1 + (Cs + Cparasitic) / Cf, the gain becomes larger than expected; i improved my layout for some day, but still not well.
i want to know, how to design or fix my layout to decrease the parasitic cap of Cs and Cf for both positive and negetice polarity, thanks.
can anyone help me?
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
dick_freebird
Helped: 46
Post29 Oct 2009 18:32
I do not know what your CS and CF mean. But you want
to drive the bottom plate (where stray capacitance mostly
resides) and take charge-critical signal off the top (or
center) plate. You can still have significant fringing capacitance
off the top plate and only keep-away distance will fix
that if you have an even number of plates. Odd number,
you can make a "pocket" cap that has no non-through
(stray) capacitance.
If you can't eliminate, but care about, substrate capacitance
you could possibly drive a well region underneath it, with
an auxiliary amplifier in phase but not in the valued signal
path, so as to eliminate a voltage-difference and charge
loss; the capacitance is still there, but "killed" by the guard.
Similar to using triax cable for ultralow leakage measurements.
Back to top
lhlbluesky
Post03 Nov 2009 13:32
Cs is the sampling capacitor, and Cf is the feedback capacitor; besides, what does "pocket" cap mean? why it needed for odd number only? i also use a N-well underneath the cap array, but only improves a little; and what's the auxiliary amplifier's meaning? and how stray capacitor killed bythe guard? can you speak more clearly? thanks.
Back to top
watersky
Helped: 2
Post03 Nov 2009 14:04
I think if Cs has parasitic cap, Cf should have parasitic cap too. The parasitic cap of every C0 is the same. So (8C0+8Cpara)/(C0+Cpara)=8.
Back to top
lhlbluesky
Post04 Nov 2009 15:56
for my case, it is a non-inverter sc amplifier, input signal in the non-inverter end, and Cs has one end grounded (in the inverter end, Av=1+Cs/Cf), so Av is very sensitive to Cs stray cap (to gnd), any other advice? and can you speak more clearly about my above questions?
Back to top
timof
Helped: 6
Post07 Nov 2009 9:08
Re: about MIM capacitor problem
can anyone help me?
What you describe sounds more like MOM capacitor, rather than MIM capacitor (MOM capacitor uses standard metal layers like M1, M2, etc. in the form of interdigitated fingers, while MIM capacitor uses special MIM metal layer separated by (usually high K) very thin (~100-200A) dielectric from one of the standard metal layers, and is formed by two large parallel plates).
Normally, popular parasitic extraction tools are just not accurate enough to be used for precision analog designs. Try to rotate your layout by 90deg, and see if you extracted capacitance value changes. Or try to compare extraction results for several nets/capacitors with identical metal surroundings, and see if you get the same capacitance values.
One needs to use a field solver (a simulator that solves first-principle equations (Laplace equation for electrostatic potential)), rather than a pattern-matching based tools for reliable and accurate capacitance extraction.
You can find some additional info at these links:
http://www.edaboard.com/ftopic277873.html
http://www.edaboard.com/ftopic366048.html
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
SMIC mim capacitor layout problem (3)
PIP capacitor VS MIM capacitor (8)
MIM capacitor (1)
mim capacitor (3)
MIM capacitor (4)
MIM Capacitor in magic (4)
MIM Capacitor in TSMC90NRF (5)
MIM capacitor mismatch (6)
MIM Capacitor layout (2)
MIM capacitor layout connections??? (1)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
