electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
antenna dual band 1575MHz Bw=40MHz 2300MHz Bw=50MHz
Post new topic  Reply to topic    EDAboard.com Forum Index -> RF, Microwave, Antennas and Optics -> antenna dual band 1575MHz Bw=40MHz 2300MHz Bw=50MHz
Author Message
sonnh87
Post27 Oct 2009 15:42
hello every body,
i am a newbie in ads. i have project to design an dual band antenna working at 1575Mhz Bw=40Mhz and 2300Mhz Bw=50Mz. how can i design it?
thank you.
Back to top
ravi8331
Helped: 95
Post28 Oct 2009 14:10
Re: antenna dual band 1575MHz Bw=40MHz 2300MHz Bw=50MHz
i think first u decide which type of antenna do u want to design e.g. microstrip antenna, PIFA or dipole etc.
after that anyone can help u.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
sonnh87
Post28 Oct 2009 17:04
i decided to design microstrip antenna and i found this paper(Submitted By:- Nandish Mehta). But this antenna working at 1.85 Ghz and 2.37Ghz. how can i change the frequency?
Sorry, but you need login in to view this attachment
Back to top
ravi8331
Helped: 95
Post29 Oct 2009 7:29
here u deeply go through this paper and then see which parameter used by author for dual frequency band and for widening the bandwidth e.g. slot length and width used for this purpose so u can introduce different type slot for this purpose.
Back to top
sonnh87
Post29 Oct 2009 18:57
i do as this paper but my S11 look so weird, its graph look likes a line.Sad
Back to top
ravi8331
Helped: 95
Post30 Oct 2009 4:59
so for doing this u hv gone through the litrature in which u see the dual band antenna design and widening the bandwidth topics and from there u get some techniques by using that u can achieve ur goal........
Back to top
ahsaan
Helped: 2
Post07 Nov 2009 16:40
Frequency is generally changed by changing the dimensions of the patch like width and length.. I havent looked at the paper u submitted but u can try changing dimensions
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
dual band antenna (6)
dual band antenna (3)
ISM Dual Band antenna (4)
Dual Band Patch Antenna (5)
Dual band gsm antenna (1)
Dual-Band F-Shaped Monopole Antenna (4)
Problem with dual-band Sierpinski antenna (8)
Inverted-F impressed dual-band (2.4 - 5.5Ghz) antenna (2)
dual band helix antenna 433MHz/868MHz (3)
a dual band circularly polarised microstrip antenna (3)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
