| Author |
Message |
vishwa
Joined: 11 Aug 2005 Posts: 156 Helped: 12 Location: India
26 Oct 2009 13:20 What is the Need of Inductor |
I have the following questions about inductors.
1. What is the need of inductor?
2. If inductor is needed only as an energy storage element, why not we go for a Capacitor for energy storage applications
3. What is the relation between the inductor size and its inductance?
4. Typical applications of inductor?
Please help me understand the inductor.
Regards,
Viswa
| Back to top |
vishwa
26 Oct 2009 13:36 Why inductors are not popular unlike capacitors |
Can anybody let me know Why inductors are not popular unlike capacitors.
Purpose wise, both inductors and capacitors are come into the same category of energy storage element and timing circuit element
Thanks,
Viswa
| Back to top |
jardila
Joined: 17 Sep 2009 Posts: 7 Helped: 1 Location: Colombia
26 Oct 2009 14:30 Re: Why inductors are not popular unlike capacitors |
Because the inductors are associate with magnetic phenomena while the capacitor is associate with electric phenomena. The electronics circuits are electric phenomena ("more electric, less magnetic").
Regards:D
| Back to top |
snafflekid
Joined: 09 May 2007 Posts: 120 Helped: 16 Location: USA
26 Oct 2009 15:15 Re: Why inductors are not popular unlike capacitors |
Inductors are less "ideal" than capacitors. Inductors are also bulky compared to capacitors.
However in RF circuitry, inductors and capacitors are equally necessary.
| Back to top |
Phytech
Joined: 30 Apr 2008 Posts: 89 Helped: 9 Location: USA
26 Oct 2009 19:51 Why inductors are not popular unlike capacitors |
| There are more variables for an inductor than for a capacitor. The way how one make an inductor strongly influence the performance, such as unloaded Q, cross talk, etc. So it's more difficult to make the inductor standard than to make a capacitor.
| Back to top |
JoannesPaulus
Joined: 19 Mar 2008 Posts: 261 Helped: 44 Location: USA
26 Oct 2009 22:08 Why inductors are not popular unlike capacitors |
| I like to think that capacitors are local elements (they are only affected by what happens between the plates) while inductors are global elements (they are affected by their surroundings as well as their design parameters) and therefore it is just more complex to get them to work as you like.
| Back to top |
Google AdSense
26 Oct 2009 22:08 Ads |
| Back to top |
vistapoint
01 Nov 2009 12:27 Re: Why inductors are not popular unlike capacitors |
because inductors are difficult to manufacture with nice accuracy and Q value. Resistors and caps are easy to control the accuracy and more close to ideal components.
______________________________________________
low-cost resistors, capacitors, and LEDs at http://store.engeecorp.com
| Back to top |
svhb
03 Nov 2009 19:10 Re: Why inductors are not popular unlike capacitors |
As simple mains transformer = 2 coupled inductors...
A more complex smps mains supply uses a high frequency transformer = also 2 coupled inductors...
In every motor --> inductors
In relays, speakers, generators, ...
A lot in power electronics.
Just a piece of cable connecting the mains to your television = inductor...
I think people doesn't like inductors because they don't understand so well as a capacitor, which just hold a voltage applied to it. In fact an inductor just holds the current you have put in (put in a current somehow, short the inductor, and the current will flow forever (theoretically))
Stefaan
| Back to top |
LvW
Joined: 07 May 2008 Posts: 1467 Helped: 242 Location: Germany
03 Nov 2009 19:32 Re: Why inductors are not popular unlike capacitors |
| svhb wrote: |
Stefaan |
Hi Stefaan,
I believe it's not a question of "like" or "dislike" . We all know that we meet inductances where ever we are and whatever we do.
However, it is a fact that engineers try to replace inductors by capacitors or by actively simulated inductive elements (GIC) wherever this is possible - especially in the field of analog signal processing. And there a good reasons to do this (as mentioned before by some other contributors). But, of course, itīs not always possible or wise.
| Back to top |
svhb
06 Nov 2009 9:39 Re: Why inductors are not popular unlike capacitors |
I think you are right for the signal processing side of it. Capacitors are far more better.
For me it looks like inductors are still important in power electronics, purely as energy storage component and not for its impedance characteristics.
Also for the more electromechanical devices (motors, relays, electromagnets), where the inductance is more seen like a parasitic effect for the function the thing is designed for.
Stefaan.
| Back to top |
betwixt
Joined: 04 Jul 2009 Posts: 389 Helped: 64 Location: Wales, UK
06 Nov 2009 11:00 Re: Why inductors are not popular unlike capacitors |
Nobody has mentioned one of the most important and common uses of inductors - to make resonant networks such as in radio tuning. It CAN be done without inductors but the alternatives are magnitudes higher in cost.
Brian.
| Back to top |
