electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
CNG level project in Car - voltage divider
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> CNG level project in Car - voltage divider
Author Message
sakender
Post24 Oct 2009 9:14
hi
i am working on the project in which i want to get level of CNG in Car and want it to digital and send it through SMS .i have some problem concern about this
i am woking IN MickroC
the CNG car used Slider resistor having two wire only. the silder on the top change value
http://www.alibaba.com/showroom/Variable_Resistor.html
as shown in figure i want a circuit in which i can change this in to voltage and can interface to pic18f452 ADC
plz help me
Sorry, but you need login in to view this attachment
Back to top
sakender
Post03 Nov 2009 7:22
Re: CNG level project in Car - voltage divider
Please any one help me out
Circuit diagram for the resister to voltage conversion
Requirement for the circuit
• The value of resistor goes to 11k at maximum value of pressure
• The value goes to zero when there is no pressure in CNG kit.
• 5V is used to define the output
 5V shows maximum pressure
 0V shows zero pressure
so plese help me
i want to select the value of R1 so please guide me
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
hameeds01
Helped: 11
Post04 Nov 2009 16:59
here it is but in this approach u have to use 2 Regulated supplies 5 and 12
0 volts for no pressure
5 volts for maximum pressure
Back to top
sakender
Post05 Nov 2009 8:47
Thx brother hameed
i will try thx agian for your reply
Back to top
sakender
Post07 Nov 2009 10:40
i have create this its working thanks Mr Hameed
Back to top
hameeds01
Helped: 11
Post07 Nov 2009 16:28
hey don't forget to press the "helped me" button
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
capacitive voltage divider in the level detector (4)
need a voltage divider for a chip project (2)
Can a voltage divider act like a voltage amplifier? (15)
Voltage Divider ground change to negative voltage (5)
Voltage regulator with a buffer + voltage divider (6)
non invasive car fuel level detector (4)
switching regulator voltage ripple vs. output voltage level (4)
Newbie car alarm alert project (6)
Car plate recognition Graduation project (3)
car battery voltage (3)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
