electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
For LED experiences college
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> For LED experiences college
Author Message
pasicr
Helped: 9
Post15 Oct 2009 8:53
Hi for all, I need advice from college with experiences in led driving, I have 50 led in series and I need driver with pic micro for example, also I need to light only 3 or 4 leds in same time and this will be shifted, to get moving athom effect in elipse...
regards
Back to top
nandhu015
Helped: 46
Post15 Oct 2009 9:56
Re: For LED experiences college
If you had connected led in series,
cant do this
Nandhu
Back to top
pasicr
Helped: 9
Post15 Oct 2009 12:53
I send three logic 1 and nothing else, only clock and shift with shift register...
regards
Back to top
nandhu015
Helped: 46
Post15 Oct 2009 13:23
Can you post the circuit so that we can help you
Nandhu
Back to top
pranam77
Helped: 93
Post15 Oct 2009 13:57
Instead of using PIC micro for such simple design, Just go ahead with a 10 channel chaser design with 555 and CD4017 and connect 5 led's per channel. You can also decrease the channel outputs by connecting the reset pin 15 to respective outputs where you want the count to reset. Have a look at the 10 channel LED chaser in the given link below. Cheers
http://www.qrp.pops.net/LEDs.asp
Back to top
sahu
Helped: 3
Post15 Oct 2009 16:49
regards
i hope its help u.
injoy with it
Sorry, but you need login in to view this attachment
Back to top
kender
Helped: 88
Location: Stanford, SF Bay Peninsula, California, Earth, Solar System, Milky Way
Post20 Oct 2009 21:32
pasicr wrote:
I have 50 led in series [...] I need to light only 3 or 4 leds in same time and this will be shifted [...]
Which of the following scenarion do you want to acheive ?
- light 1,2,3,4 then 2,3,4,5 then 3,4,5,6 etc
- light 1,2,3,4 then 5,6,7,8 then 9,10,11,12 etc
Another question - how much current do you need to drive?
Back to top
pasicr
Helped: 9
Post20 Oct 2009 22:03
scenario light 1,2,3,4 then 2,3,4,5 then 3,4,5,6 etc
I use red 5mm led...
regards
Back to top
kender
Helped: 88
Post20 Oct 2009 22:33
In this scenario, essentially, you need individual drive for each LED. I would recommend common anode* for all 50 LEDs instead of connecting them in series. Cathodes connected to a shift registers. I don't have the part number for the shift register on the top of my head. But I'm sure folks here can suggest specific parts.
- Nick
* Common cathode could work as well. I'll stick with common anode for certainty.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
JARI NETWORKS
Post04 Nov 2009 14:58
you can also try to put it in a matrix
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
Which LED to USE For LED DISPLAY (2)
College project ideas,stuck for ideas! (4)
College Project (2)
NEED college miniProject help (2)
college project PDA with GPS (16)
Experiences in Mentor IC Flow 2006 (1)
College Physics, Sixth Edition, Serway, Solutions? (6)
Help with my college project (RFID Chips)? (2)
PLEASE HELP ME WITH MY COLLEGE THESIS :cry: (1)
technology migration experiences and tools (3)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
