electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Digital calendar using ds1307 0r ds12887
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> Digital calendar using ds1307 0r ds12887
Author Message
rashidali
Post08 Oct 2009 6:17
Hi:
I am using ds1307 and ds12887 as digital calendar. I have developed code for displaying the today's day, date month and year. The problem is that I want to make a calender which is displayed on lcd and then I can select any day from it, just like in nokia 1208 mobile, which displays calendar and i can select any date or even change year by scrolling down.
I shall be very thankful to you for your support.
Thanks
Back to top
vipul
Helped: 1
Post08 Oct 2009 9:17
Hi rashidali..
U have developed code for calender using RTC... so now u have to just take data from user using keys...and as per the data entered by user u have to set parameter in RTC...
read RTC continuously and print on LCD...
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
sharang
Post07 Nov 2009 7:27
#include<reg51.h>
#include<absacc.h>
sbit RS=P1^2;
sbit RW=P1^3;
sbit E=P1^4;
void put(unsigned char ch,bit rs);
void delay(unsigned int t);
void init(void);
void main()
int i=0x00;
delay(500);
//P0=0xFF; //Input Port
init();
put('R',1);
put('T',1);
put('C',1);
put(0xC0,0);
delay(2);
XBYTE[10]=0x20;
XBYTE[11]=0x83;
XBYTE[11]=0x03;
XBYTE[0]=41;
//XBYTE[11]=0x03;
while(1)
put(0xC0,0);
for(i=0x00;i<0x0A;i++)
// XBYTE[0]++;
put((XBYTE[0]<<0x0F)+0x30,1);
delay(500);
put(0x94,0);
put((XBYTE[10]<<0x0F)+0x30,1);
/*if(XBYTE[0]>=0x39)
XBYTE[0]=0x30;
void init(void)
put(0x3C,0); //Set interface length
put(0x01,0); //Clear the display
put(0x06,0); //Set cursor move direction
put(0x0E,0); //Enable display cursor
return;
E=1;
RW=0;
P2=ch;
RS=rs;
delay(1);
E=0;
delay(1);
RW=1;
return;
{ unsigned int k,l;
for(l=0;l<t;l++)
for(k=0;k<900;k++);
return;
PLEASE HELP
Back to top
Noman Yousaf
Helped: 1
Post09 Nov 2009 15:26
hi rashid
i think u r ------
any how your problem is not as easy dear.
rtc runs the time and calender but searching is not possible.
you want to search the date and month day wise?
simply u have to use memory for this. first save all the dates and months in mem then use it for searching
you use 3 bytes for date as, 1 byte for date (1-31), 1 byte for month (1-12) then 1 bhye for year (00-99).
now memory size could be, 3(bytes per day) x 365 (days per year) = 1095 bytes for 1 year i think u got it. if not then tell me i will tell you more.
bye
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
code for digital clock using ds1307+pic16f877a+lcd (3)
PIC16F628 DIGITAL CALENDAR CLOCK CIRCUIT WITH LED (2)
rtc project using 89c52 and ds12887 (1)
RTC programs using Dallas DS1307(CodevisionAVR)??? (5)
Regarding RTC DS1307 - using it without a battery (4)
where to find rtc programs using Dallas DS1307? (21)
real time clock using pic16f877 and DS1307 (13)
Electronic Calendar. (3)
AT89C51 CALENDAR CLOCK (5)
Problem with RTC Chip DS1307 with PIC18F452 using Hi-Tech C (3)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
