electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
LPC2148
Post new topic  Reply to topic    EDAboard.com Forum Index -> Embedded Systems and Real-Time OS -> LPC2148
Author Message
prasannavenkatesh
Post24 Sep 2009 6:57
LPC2148
Hi, I am new for this forum
I have lpc2148 ic how to program to flash memory.
i have lpc2000 flash utility ver2.2.3 when i connect the target board to pc and start programming the error msg will appear cant communicate with board.
i check my hardware that connection properly vss,vdd and P0.14 pin pull to low then i cant choose the device in the flash utility. how to program the lpc2148
Any one help to me and explain step by step
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
s3034585
Helped: 1
Post29 Sep 2009 2:50
Re: LPC2148
try flashmagic utility. lpc2000 flash utility dosent support lcp2148. start with flashmagic using smaller baud rate and go on increasing till you can communicated with the chip.
Back to top
prasannavenkatesh
Post06 Oct 2009 7:01
Re: LPC2148
hi,
I also try falshmagic but i cant programming.........
tell the detail of programming in step by step
Back to top
nishantmb
Post10 Oct 2009 10:14
Re: LPC2148
there is an issue of your board not able to communicate make sure your board resets well. i.e. reset ckt is working properly.
After that go throu the manual of flash magic if this does not work le t me know
Back to top
prasannavenkatesh
Post10 Oct 2009 11:40
Re: LPC2148
Every one pls send me the proper circuit for programming lpc2148 and how to program explain step by step pls send to my email id prasanna281985(at)gmail.com
Back to top
amol_gharpure
Post05 Nov 2009 7:22
Re: LPC2148
In flash magic pls make sure that you have selected the Automatic Reset option.
Back to top
s3034585
Helped: 1
Post10 Nov 2009 10:37
Re: LPC2148
just copy U2 related circuit and you will be able to program using flash magic
Sorry, but you need login in to view this attachment
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
micro LPC2148 (3)
USB on Philips LPC2148 (1)
help me ADC on LPC2148 (10)
adc interfacing in lpc2148 (4)
LCD with LPC2148 (1)
configuration of USB at lpc2148 (3)
LPC2148 & USB help (1)
HELP ADC in ARM7 lpc2148 (3)
OrCAD Library From LPC2148 (5)
Problem with Lpc2148 Uart (2)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
