| Author |
Message |
rvillene
05 Feb 2009 17:02 horn antenna pattern |
Could you please help me to design a pyramidal horn antenna and obtain his radiation pattern with HFSS?
Thanks
| Back to top |
EMscuba
09 Feb 2009 13:33 radiation pattern of horn antenna |
| Not sure about HFSS, but how about in FEKO? The model can be downloaded if you're a user.
| Back to top |
Ivan_
Joined: 16 Nov 2007 Posts: 111 Helped: 21 Location: ITALY
10 Feb 2009 23:45 horn antenna radiation pattern |
What do u mean? I guess u need how to know how to draw it and simulate it, don't you? The easiest way to do it is to create the pyramidal structure by using polylines. I designed some horns in the past. If u are interested on it I can upload a sample file.
Should you need equations to design ur horn u can find them in 'Antenna Theory' book by C. Balanis (I seem it is chapter 11, but I'm not sure). Let me know if this is enough or u need the sample file.
I.
| Back to top |
Google AdSense
10 Feb 2009 23:45 Ads |
| Back to top |
ahmed_hussein144
19 Feb 2009 19:27 radiation pattern horn antenna |
| hi all, if there is some one can help me, I need example in HFSS to design Double ridge Horn Antenne,
| Back to top |
kamran aslam bhatti
01 May 2009 10:29 horn antenna theory |
i want to design wideband pyramidal horn antenna in hfss, and i have done calculations of waveguide and flared part but dont know how to make it, if u anyone can help me kindly mail me on my id
spectrum6115(at)hotmail. or at yahoo with same id
plz help me as soon as possible.
| Back to top |
anil_21p
02 May 2009 16:46 horn antenna patterns |
| Can you give design parameters of Horn?
| Back to top |
kamran aslam bhatti
08 May 2009 15:31 horn antennen |
i want to design it in the range of 1Ghz to 3Ghz, here are parameters with 15dB gain and cutoff frequency of 0.95Ghz,
a = 15.789cm (one dimension of waveguide)
b = 7.8945cm (2nd dimension of waveguide)
a1 = 39cm (dimension of horn surface)
b1 = 28.371cm (dimension of horn surface)
length of horn surface = 16.44cm
length of waveguide = 8.494cm
i calculate all these with the help of design procedure given in Balanis's book, and calculation of waveguide from David A.Pozar. i will wait for your reply, i need any modal of wide band horn antenna in HFSS working over any range. so that i may get help regarding design.
i am attaching a file kindly check it too. although it seems very good, but problem with it is, that it does not start from zero , kindly comment over it too.
| Back to top |
kamran aslam bhatti
12 May 2009 20:46 pattern of horn antenna |
| i have done it, no thanx to anyone, couze nobody help me. i myself have to make it. if anybody want any help regarding horn antenn, he can contact me through my email id.
| Back to top |
nonoaly2006
14 Jul 2009 13:11 pyramidal horn antenna radiation pattern |
| please can i have any help in horn antenna design
| Back to top |
RFDonno
01 Nov 2009 17:39 Re: Horn Antenna and radiation pattern |
Hi Kamran, could you please post your email address. I'm also trying to design a horn antenna. I could use you guidance on the matter.
Kind regards,
Don
| Back to top |
Abhishekabs
Joined: 12 Jan 2007 Posts: 727 Helped: 84 Location: India
05 Nov 2009 7:00 Horn Antenna and radiation pattern |
Hi Kamran,
The Broadband antenna you want to design is not simple horn.
You need to add ridges in the waveguide & horn section to increase your bandwidth.
Search for Double or quadridged horn design in search engines.
You will get many papers or references.
If you stuck at any point then you can send me personal messege.
| Back to top |
