| Author |
Message |
jithesh
Joined: 11 Oct 2007 Posts: 91 Helped: 12 Location: India
15 Apr 2008 11:22 fdtd matlab |
Hi all,
The following book 'The Finite Difference Time Domain Method for Electromagnetics: With MATLAB Simulations' by Atef Elsherbeni and Veysel Demir
is scheduled to be released in July 2008 by SciTech Publishing.
The List Price is: $125.00.
I think it contains almost every thing in FDTD from a plactical impelmentation point of view and answers most of the queries.
Have a look at the Table of Contents:
1 Introduction to FDTD
1.1 FDTD Basic Equations
1.2 Approximation of Derivatives by Finite Differences
1.3 FDTD 3D
1.4 FDTD 2D
1.5 FDTD 1D
1.6 Exercises
2 Numerical Stability and Dispersion
2.1 Numerical Stability
2.2 Numerical Dispersion
2.3 Exercises
3 Building Objects in The Yee Grid
3.1 Code: Definition of Objects
3.1.1 Defining The Problem Space Parameters
3.1.2 Defining The Objects in The Problem Space
3.2 Material Approximations
3.3 Subcell Averaging Schemes
3.4 Objects in The Yee Grid
3.5 Code: Creation of Material Grid
3.6 Improved Eight-Subcell Averaging
3.7 Exercises
4 Active and Passive Lumped Elements
4.1 Voltage Source Updating Equation
4.2 Hard Voltage Source
4.3 Current Source
4.4 Resistor
4.5 Capacitor
4.6 Inductor
4.7 Distributed Lumped Elements
4.8 Diode
4.9 Summary
4.10 Simulation of Lumped Elements
4.10.1 Definition of Lumped Elements
4.10.2 FDTD parameters and Field Arrays
4.10.3 Initialization of Lumped Element Components
4.10.4 Initialization of Updating Coefficients
4.10.5 Sampling Electric and Magnetic Fields, Voltages and Currents
4.10.6 Definition and Initialization of Output Parameters
4.10.7 Running an FDTD Simulation: The Time Marching Loop
4.10.8 Displaying FDTD Simulation Results
4.11 Simulation Examples
4.11.1 A Resistor Excited by a Sinusoidal Voltage Source
4.11.2 A Diode Excited by a Sinusoidal Voltage Source
4.11.3 A Capacitor Excited by a Unit-Step Voltage Source
4.12 Exercises
5 Source Waveforms
5.1 Common Source Waveforms
5.1.1 Sinusoidal Waveform
5.1.2 Gaussian Waveform
5.1.3 Normalized Derivative of a Gaussian Waveform
5.1.4 Cosine Modulated Gaussian Waveform
5.2 Initialization of Source Waveforms
5.3 Code: Time to Frequency Domain Transformation
5.4 Simulation Examples
5.4.1 Recovering a Time Waveform from its Fourier Transform
5.4.2 An RLC Circuit
5.5 Exercises
6 S-Parameters
6.1 S-parameter Definition
6.2 S-Parameters Calculation
6.3 Exercises
7 Perfectly Matched Layer
7.1 Theory of PML
7.1.1 Theory of PML at vacuum-PML interface
7.1.2 Theory of PML at PML-PML interface
7.2 PML 3D
7.3 PML Loss Functions
7.4 PML Updating Equations
7.4.1 PML Updating Equations - 2D TEz
7.4.2 PML Updating Equations - 2D TMz
7.4.3 MATLAB Implementation of 2D FDTD with PML
7.5 Simulation Example
7.6 Exercises
8 CPML
8.1 Formulation of CPML
8.1.1 PML in Stretched Coordinates
8.1.2 Complex Stretching Variables in CFS-PML
8.1.3 The Matching Conditions at The PML-PML Interface
8.1.4 Equations in Time Domain
8.1.5 Discrete Convolution
8.1.6 The Recursive Convolution Method
8.2 The CPML Algorithm
8.2.1 Updating Equations for CPML
8.2.2 Addition of Auxiliary CPML Terms at Respective Regions
8.3 Parameter Distribution
8.4 MATLAB Implementation of CPML in 3D FDTD
8.4.1 Definition of CPML
8.4.2 Initialization of CPML
8.4.3 Application of CPML in FDTD Loop
8.5 Simulation Examples
8.5.1 Microstrip Low-Pass Filter
8.5.2 Microstrip Branch Line Coupler
8.5.3 Characteristic Impedance of a Microstrip Line
8.6 Exercises
9 Near-Field to Far-Field Transformation
9.1 Implementation of Surface Equivalence Theorem
9.1.1 Surface equivalence theorem
9.1.2 Equivalent surface currents
9.1.3 Antenna on infinite ground plane
9.2 Near Field to Far Field Transformation
9.2.1 Time domain to frequency domain transformation
9.2.2 Vector potential approach
9.2.3 Polarization of radiation field
9.2.4 Radiation efficiency
9.3 MATLAB Implementation of NF-FF Transformation
9.3.1 Definition of NF-FF Parameters
9.3.2 Initialization of NF-FF Parameters
9.3.3 NF-FF DFT
9.3.4 Postprocessing for Farfield Calculation
9.4 Simulation Examples
9.4.1 Inverted-F Antenna
9.4.2 Strip-Fed Rectangular Dielectric Resonator Antenna
9.5 Exercises
10 Thin Wire Modeling
10.1 Thin Wire Formulation
10.2 MATLAB Implementation of Thin Wire Formulation
10.3 Simulation Examples
10.3.1 Thin Wire Dipole Antenna
10.4 Exercises
11 Scattered Field Formulation
11.1 The Scattered Field Formulation
11.2 The Scattered Field Updating Equations
11.3 Incident Plane Waves
11.4 MATLAB Implementation of Scattered Field Formulation
11.4.1 Definition of Incident Plane Wave
11.4.2 Initialization of The Incident Fields
11.4.3 Initialization of The Updating Coefficients
11.4.4 Calculation of The Scattered Fields
11.4.5 Post-processing and Simulation Results
11.5 Simulation Examples
11.5.1 Scattering From a Dielectric Sphere
11.5.2 Scattering From a Dielectric Cube
11.6 Exercises
12 GPU Acceleration of FDTD
12.1 Graphical Processors and General Math
12.2 Introduction To Brook
12.3 Sample 2D Implementation Using Brook
12.4 Extension Into 3D
12.5 Exercises
A One-Dimensional FDTD Code
B CPML Regions and Associated Field Updates for a 3D Domain
B.1 3D CPML Ex
B.2 3D CPML Ey
B.3 3D CPML Ez
B.4 3D CPML Hx
B.5 3D CPML Hy
B.6 3D CPML Hz
C Matlab Code for Plotting Farfield Patterns
Index
Bibliography.
Best regards
Jithesh
| Back to top |
shenhongj2004
07 May 2008 0:45 fdtd matlab book |
| It look good , where can I find it? can you send it to me please? my email is shenhongj2008(at)hotmail.com
| Back to top |
jithesh
07 May 2008 1:59 fdtd using matlab |
hi friend
this book is not yet released. the release is scheduled for july 2008 by SciTech Publishing.
best regards
jithesh
| Back to top |
shenhongj2004
03 Aug 2008 14:42 fdtd examples matlab |
| as you said, i guess this book has been published.
| Back to top |
rashidmirza
05 Aug 2008 15:23 matlab fdtd |
| shenhongj2004 wrote: |
| as you said, i guess this book has been published. |
where?
If possible upload that, tnx.
| Back to top |
obhro
19 Aug 2008 2:46 fdtd+matlab |
Is it possible to get the book "The Finite Difference Time Domain Method for Electromagnetics: With MATLAB Simulations" ?????
My email address is obhro23(at)hotmail.com
BR
| Back to top |
MusicMan
03 Sep 2008 14:05 ftdt matlab |
hi everyone... ifsomeone has the book pls sent it to me. tnx
my email is: brrrrrgrrrrr(at)yahoo.com
| Back to top |
Google AdSense
03 Sep 2008 14:05 Ads |
| Back to top |
exlove
14 Oct 2008 17:05 matlab ftdt |
Hi
Can I get this book?
I need this!!!!!
My e-mail is exlovep(at)gmail.com
tnx
| Back to top |
jithesh
15 Oct 2008 2:15 fdtd with matlab |
This book is still in production with publication scheduled for November 2008.
Source of info: http://www.scitechpublishing.com/index.asp?PageAction=VIEWPROD&ProdID=469
Best Regards
Jithesh
| Back to top |
luhai123
11 Nov 2008 5:53 yee algorithm matlab |
Hi, Everybody.
The time has been delayed. This book is in production with publication scheduled for December 2008.
| Back to top |
Souvikda
10 Dec 2008 11:08 3d thinning matlab |
please upload this book after publication....
this is very good book
| Back to top |
luhai123
27 Dec 2008 6:14 w.google.com |
| Who can share this book, I want to do some work about the FDTD.
| Back to top |
hamidrezakarami
05 Jan 2009 13:25 ftdt, matlab |
Hi
sen me this book when you find it
Tnx
| Back to top |
t25
10 Jan 2009 10:29 cpml implementation |
| it have hard cover
| Back to top |
telecant
03 Mar 2009 10:34 infinite ground plane fdtd |
dose any body have the book FDTD using Matlab?
if yes send it to my email pleas!
boulkadid_ali(at)hotmail.com
| Back to top |
khak
27 Apr 2009 7:45 fdtd adi 2d download matlab |
I need this book too, if anybody have it plz send me a copy of it
khaksarkalati(at)gmail.com
| Back to top |
exlove
03 May 2009 11:32 gpu fdtd solver matlab |
can i get this book?
i need this book!!!
email)exlovep(at)gmail.com
| Back to top |
zog
15 May 2009 11:33 a example of fdtd solution in matlab |
need the book, if anyone has downloaded it!!!
thanx in advance
email: kangwa@ mail.ru
| Back to top |
bawilia81
07 Jun 2009 3:49 defineyee grid |
where can i download it i need it urgently if some one has pls send me afsharibawili(at)gmail.com
thx alot
| Back to top |
xi2009
16 Jun 2009 5:37 matlab microstrip fdtd code |
Is there any body have the e-book !!And where we can download it!!if you have this book,could you send one to E-mail:h381963517(at)126.com.
with kind regards.
| Back to top |
alberto_micro
17 Jun 2009 21:38 fdtd using matlab elsherbiny |
I found a novel book named
2-D Electromagnetic Simulation of Passive Microstrip Circuits
CRC Press
by Alejandro Dueñas Jimenez
I learn much about FDTD an a few of static MoM
is easy to understood.
I recommend it.
| Back to top |
jithesh
16 Jul 2009 13:25 nf to ff transformations |
Hi
I have the Wonderful Matlab codes associated with this book with me. If I post it here, will it be a violation? TO use the code One may need to refer the book because it is developed incrementally. codes in individual chapters may not work independently. However I will try to combine them as per each example's requirement and try to post them. This may take some amount of time. Pls wait.
Best Regards
Jithesh
| Back to top |
smruti
17 Jul 2009 7:04 related:doi.wiley.com/10.1002/cae.1015 |
respected jitesh,
i think ur able to download the above book from this site,
http://en.pudn.com/downloads161/ebook/detail726054_en.html
| Back to top |
sianturi_familly
17 Jul 2009 8:04 theory cpml +fdtd |
ada yg bisa berbagi buku ini kepada saya....
saya ingin menyelesaikan Tugas Akhir ttg FDTD dalam Mikrostrip....
email saya:
sianturi_familly [at] yahoo.co.od
| Back to top |
iyami
17 Jul 2009 13:05 fdtd book download |
| Quote: |
PostPosted: 17 Jul 2009 8:04 Post subject: FDTD using Matlab
respected jitesh,
i think ur able to download the above book from this site ...
that's just the source code
| Back to top |
jithesh
18 Jul 2009 7:01 lumped element using fdtd method and matlab |
Yes. The code in en.pudn.com is just the code associated with Chapter 1 and it computes and plots the error associated with forward, backward and central differencing algorithms for approximating a derivative
regards
Jithesh
| Back to top |
smruti
03 Aug 2009 15:14 ,+fdtd ,+lumped ,+source code |
i am sorry,mr iyami and mr jitesh,
i think that link contains the above book.
| Back to top |
jithesh
04 Aug 2009 2:47 fdtd voltage source hard source |
| Yes I do agree partially. The above link contains the full MATLAB code associated with the book but I couldn't find the e-book there.
| Back to top |
Zottiri Kusuta
Joined: 02 Sep 2005 Posts: 75 Helped: 13 Location: Columbus, OH
04 Aug 2009 6:19 numerical simulation code matlab diode |
| if you like the book so much, just buy it... huh? don't expect anyone to send it to you with an e-mail. LOL!
| Back to top |
smruti
05 Aug 2009 12:07 2d fdtd grid capacitance |
mr jitesh,can u send me the matlab code,i want to see this.otherwise upload here.
Added after 7 minutes:
for mr jitesh,
i have a request,have u a adi-fdtd in 1 dimension using matlab code.
if u have it,please upload here,i am interested to study about this topic.
this code is also available on www.pubn.com
please help me.
| Back to top |
