| Author |
Message |
atmelAVR91
26 Dec 2006 9:34 keil and uc/os-ii |
I want to use Keil ARM Compiler and Texas TMS470 uC with uC/OS-II.
But Keil Does't Support uC/OS-II.
Do I have any option other than switching to IAR ARM Compiler ?
| Back to top |
Google AdSense
26 Dec 2006 9:34 Ads |
| Back to top |
alzomor
Joined: 09 Jun 2005 Posts: 626 Helped: 31 Location: Cairo
03 Jan 2007 4:47 does keil support uc-os ii |
Hi
I think UC-OS II is compiler independent.
With some coding you can compile your code using Keil.
This is my openion
Salam
Hossam Alzomor
www.edaboard.com
| Back to top |
amraldo
Joined: 29 Aug 2004 Posts: 287 Helped: 25 Location: egypt, cairo
23 Jan 2007 12:02 ucos-ii keil |
AA,
You have to port it to your compiler. You can check ucos-ii website to see if any has compiled it before using Keil. I advice you to start from a ported version to your hardware that used another compiler (you wil be sure that the hardware part is done) & you will only need to do the compiler porting.
Regards,
Amr Ali.
| Back to top |
manu_ec
05 Nov 2009 6:10 Re: Does Keil Support uC/OS-II ? |
Hi all,
Yes it(Keil) supports...
has it is only source code...
we can compile that using keil...
| Back to top |
