electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Nokia 5110 LCD
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers -> Nokia 5110 LCD
Author Message
DrWhoF
Helped: 12
Post04 Jul 2006 9:54
nokia 5110 lcd
How can I connect Nokia5110 LCD to microcontroller?
Thanks,
DrWho
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
IanP
Helped: 1542
Post04 Jul 2006 10:33
5110 lcd
An example on how to connect this LCD to PICAXE-18X was published by the Silicon Chip in June this year .. below is the diagram ..
http://www.siliconchip.com.au/cms/A_107010/article.html
Software for this project can be downloaded from the Silicon Chip website ..
Regards,
IanP
Sorry, but you need login in to view this attachment
Back to top
polymath
Helped: 23
Post04 Jul 2006 12:19
picaxe lcd
PIC16F84A to 5110 LCD with ASM code:
http://sandiding.tripod.com/lcd.html
The site has links to controller, circuit description etc.
Have a look here too:
http://serdisplib.sourceforge.net/ser/pcd8544.html
regards ... Polymath
Back to top
DrWhoF
Helped: 12
Post05 Jul 2006 9:46
nokia5110 lcd
Actually I connected my PICAXE according to IanP's diagram and LCD according to link given by POLYMATH and I tired to program PICAXE with BASIC code from Silicon Chip but PICAXE programmig software displays message that PICAXE is not connected. It is connected via RS-232 in normal way: 10k and 22k. What is the problem?
Thanks
DrWho
Back to top
IanP
Helped: 1542
Post05 Jul 2006 11:16
lcd 5110
If you are sure that both connections (Rx and Tx) are correct then the only one thing that can be, and probably is, suspicious is the supply voltage, 3.3V that is ..
To connect LCD you have to lower the standard supply from 5V to 3.3V ..
In normal circumstances even 0-5V for RS-232 standard wouldn't be enough, but nowaday's computers can "understand 0-5V levels (instead of defined by the RS-232 standard: -25-3 and +3+25) ..
So, here you have the microcontroller supplied of 3.3V and you still expect the RS-232 port to work correctly?!?!?!
It is quiet possible the PIC (PICAXE in this case) can receive transmission from the PC but what it tries to send back its feedback (acknowledgment) it is just below acceptable level and therefore your PC tells you: NOTHIG CONNECTED ..
To program PICAXE disconnect LCD, connect 5V supply to PICAXE and try again ..
Regards,
IanP
Back to top
i-rot
Post27 Apr 2008 16:25
lcd picaxe
http://users.bigpond.net.au/robert_gatt/nokia/nokia.html
check this out.
i found it but i need to send text to lcd by rf module how can i do it ?
Back to top
Nimish
Helped: 1
Post31 May 2008 8:16
nokia5110
Nokia 6610 color LCD interfacing
http://lcdinterfacing.googlepages.com/colorlcd
Back to top
Nimish
Helped: 1
Post05 Nov 2009 5:49
Re: nokia5110
new link http://www.lcdinterfacing.info/Interface-Nokia-6610-LCD.php
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
LCD graphic S1D15G00 (Nokia 6100 LCD) (1)
Nokia 3310 LCD (4)
Nokia 3310 LCD (1)
Nokia 3510i LCD (4)
PCB OF NOKIA LCD??? (2)
Nokia 3110 LCD (8)
NOKIA 6610 LCD (1)
Interfacing to Nokia Phone LCD (31)
question of nokia 3310 lcd (8)
90S2313 and Nokia LCD (6)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
