| Author |
Message |
ful babu
Joined: 11 Nov 2004 Posts: 167 Helped: 11 Location: Singapore
27 Aug 2005 17:11 gtp usb |
i need GTP USB and GTP USB-232 schematics, pcb can any one help ? and also want to kno the difference betn these two.
thx
| Back to top |
metal
27 Aug 2005 20:34 gtp-usb |
Hello
Download this one:
http://perso.wanadoo.es/siscobf/descargas/WinPic800.zip
it includes the programmer siftware and two folders for GTP USB and GTP USB-232 schematics.
Open the programmer and go to hardware setup, you will find lots of links, some contain PCB designs.
Good Luck
| Back to top |
ful babu
28 Aug 2005 9:02 gtp usb plus |
well, in schematic there is a inlet for RXD,TXD,RTS and DSR but no usb, so i am assuming i sud connect a standard usb-232 converter in there, am i right ?
thx
| Back to top |
metal
28 Aug 2005 9:51 gtp usb programmer |
Hey
I don't think it is really hard to get it, if you read the last post thoroughly, and examined the scematics, I am sure you will find two schematics, one for USB, and the other for RS-232.
So I don't know what are you talking about, USB-RS232 ??? What is that has to be done, convert RS-232 to USB or vice versa ??? I don't think you will need that, just adapt the one you need, build the circuit, and burn the PIC, thats all !!!
| Back to top |
ful babu
28 Aug 2005 13:23 gtp-usb plus |
well 2 questions in reply ,
1. then, why the schematic is named as GTP USB-232 if it is only a RS-232 port programmer, i.e. why it has 'USB' with it ?
2. in winpic800, in hardware settings there are 4 options, LPT, COM, USB, USB-232. so wat is the difference betwn 'COM' and 'USB-232' if they are the same ??
thx
Added after 11 minutes:
i was right indeed, here is a picture tat used a usb-rs232 converter
| Back to top |
metal
28 Aug 2005 21:48 gtp usb plus firmware |
Hello
The options are for ports, there are some readly built modules to convert USB to RS-232, but I think this is waste of time, because you already got a schematic that connects directly to the USB.
Also, not all options you see are usable, for the GTP case, its just the USB, or RS-232. LPT is not applicable here.
Good luck
| Back to top |
38gazili
21 Sep 2005 21:44 gtp usb lite |
| Anyone know the schematic of "8/18/28/40 Pin ZIF Adapter " for Winpic800 programmer? I just want to make one. please help me .Thank you.
| Back to top |
metal
22 Sep 2005 0:35 gtp-usb [ plus ] |
Hello
In the hardware section of WINPIC800 you will find links for each supported programmer, follow the links and you will find schematics, and PCB designs you are looking for...
Good luck
| Back to top |
wizpic
23 Sep 2005 1:26 gtp usb schematic |
Metal
| Quote: |
| In the hardware section of WINPIC800 you will find links for each supported programmer, follow the links and you will find schematics, and PCB designs you are looking for... |
I have had a look through all the links in the hard ware but can only find the schematics and PCB for pogrammer and not the 40PIN ZIF socket i think like the that MELABS sell thats what the ohter guys after
well unless i'm blind. if anyone has got can you help us out
question for you boys and girls is the GTP USB programmer any good
cheers
wizpic
| Back to top |
metal
23 Sep 2005 1:43 gtp usb lite programmer |
Hello
Here is what the guys who built GTP stuff used for ZIF sockets....Hope its of help man
BTW
No body is blind as long as they do the right search
| Back to top |
thenorthstar
28 Apr 2006 17:11 gtp-usb full |
Hello
I have GTP-USB Lite programer and I used this,but I have same problem
I am programing another pic family but I don't programing 16F84a and 16F628 I don't understand. I don't know where I make error.
please help me
| Back to top |
gonenc
03 Jun 2006 20:18 gtp usb plus schematic |
"Hello
please help me "
I solved that problem today by putting 100uF to the output of ICSP connector
(between VDD and GND) If you wish you can do the same for USB connectro side
The necessity for that comes from some pics uses much current so you need an additional supply or large capacitors for the output voltage (5V) not to dropout
For example: While using ICD2 you generally need an extra power supply
I sitll have problems (does not work with Winpic3.58 and resets when I touch the bottom of PCB)
Which hex and driver did you use
I hope it became usefull
Gonenc
| Back to top |
ful babu
22 Jul 2006 19:38 gtp-usb programmer |
any one have gtp usb+ schem. and hex ?
thx
| Back to top |
nooknikz
Joined: 22 Apr 2002 Posts: 404 Helped: 22 Location: thailand
22 Jul 2006 19:39 gtp_usb |
| here
| Back to top |
Google AdSense
22 Jul 2006 19:39 Ads |
| Back to top |
wjr1955
Joined: 11 May 2006 Posts: 32 Helped: 2 Location: Sao Paulo BR
22 Jul 2006 20:18 gtp usb plus pcb |
| gonenc wrote: |
"Hello
Gonenc |
GT USB Lite works only on Winpic800 3.55 version.
| Back to top |
ful babu
23 Jul 2006 14:43 gtp-usb plus hex |
i said gtp usb + "plus" not the gtp usb, my isp has blocked the domain http://perso.wanadoo.es/ so i cannt get into any information on tat page, i heard tat i hav to buy the ic for tat one, can any one explain me how to get
| Back to top |
pic-novato
Joined: 05 Feb 2006 Posts: 50 Helped: 1 Location: Lima - Peru
23 Jul 2006 15:53 gtp-usb programer |
Hello Fat Babu:
GTP USB PLUS is not free, you need to contact with Francisco (Sispic)
winpic800(at)hotmail.com
Have various opcion to buy, only the pic programmed, pcb, or programmer ready to use.
You need the software Winpic800, but its free.
If you have more cuetions maybe i can help you.
Regards.
| Back to top |
ful babu
24 Jul 2006 15:05 pic usb schematic |
| pic-novato wrote: |
Hello Fat Babu:
.... you need to contact with Francisco (Sispic)
Have various opcion to buy, ...
Regards. |
first of all, ITS NOT FAT BABU it is ful babu, any way, no body is replyin form winpic800(at)hotmail.com ... can any tell me is he still he is alive ?
| Back to top |
pic-novato
25 Jul 2006 18:37 gtp usb pic |
Ful Babu:
I make a mistake and apologize for it, but i only try to help you.
Sispic is still alive.
Any way, if you don't have good ways i can't help you.
Bye
| Back to top |
phamxba
28 Jul 2006 4:31 gtp usb firmware |
I has make a GTP_USB board but it not working with WinPIC800 v3.59 I thinh if who can update the driver for Board (18f2550) it will be done ....but who can do,please post it for me
thanks advance
this my mail luongvanthieu(at)yahoo.com
| Back to top |
PICUser
23 Aug 2006 8:22 components of gtp usb programmer |
Hi friend,
can somebody share with forum shematic or link from where to DL latest version of Melabs programmer ( supports usb and rs232 interfaces). I have old version (only RS232 interface).
Thanks in advane
Best regards
PICUser
| Back to top |
wakaka
23 Aug 2006 9:08 gtp-usb |
can anyone specify the connection pin from VPP, Vss, Data, Clock to PIC??
and for Vpp, Vpp2,Vss,Data Clock.
wats the difference between these 2 groups?
how to connect from GTP USB to PIC, need to include any passive components?
both can be used?? Y the upper part need an extra Vpp2??
tankx
| Back to top |
wakaka
24 Aug 2006 2:57 gtp schematic |
| does it need any external power supply suring programming for the ICSP?? or it takes power supply from the targeting board??
| Back to top |
shak
29 Aug 2006 16:48 gtp usb plus hex |
there is new microcontrollers and compatable with 8051
lik : c54u
usb 97c100
an212 ezusb
| Back to top |
pic-novato
29 Aug 2006 21:54 gtp programmer |
Wakaka:
The ICSP don't need power from the Pic circuit, don't connect power from the GTP USB to power from the Pic circuit, only connect the ground of both circuits and Vpp, Data and Clock.
The GTP USB have to groups of connectors:
Vpp, Vss, Data and Clock for the ICSP.
Vpp, Vpp2, Data and Clock for the ZIF where you put the pics.
If youdon´t have the diagram for the ZIF, messege me.
Bye
| Back to top |
phamxba
30 Aug 2006 1:52 usb schema |
I have consider the GTP_USB lite and GTP_USB i look out the different between that schematic is the Vpp2 on the GTP_USB so that they can building a simple socket for programming many chip on once. final, the my object is find the schematic and hex file for building o good programming board .
Who person really can help me and indicate clearly about that source .
Thanks advance .
Because notthinglast forever !
| Back to top |
wakaka
31 Aug 2006 13:06 gtp-usb summer 2005 |
| pic-novato wrote: |
Wakaka:
Bye |
i see, thanks for ur reply, i need the ZIF diagram, plz upload, thankx. If possible, the hex file and schematic for it as well....thanx....
| Back to top |
hngm
31 Aug 2006 17:27 gtp-usb firmware |
GTP USB_232 schematic
| Back to top |
hngm
31 Aug 2006 17:31 gtp usb full |
GTP_USB....
| Back to top |
ful babu
10 Sep 2006 11:19 gtp-usb-lite |
any one have the pcb layout for gtp usb ( not gtp-usp+ , gtp usb-232)
thx
| Back to top |
