| Author |
Message |
tjalps
23 Jan 2005 20:17 zigbee howto |
Hello!
I'm starting with ZigBee design, because I think that it realy has great potetntial because of price and usability.
Did anyone tried Microchip demo and how it works? How is with stack?
Can you sugest with what is best to start?
Can we realy achive 25m distances and more?
Please, write anything what you think is good for new people on this subject!
regards!
| Back to top |
svicent
23 Jan 2005 20:55 zigbee design |
Issue 175 (February 2005) of Circuit Cellar magazine contains Part 1 of a tutorial on ZigBee. The tutorial contains two parts.
| Back to top |
Google AdSense
23 Jan 2005 20:55 Ads |
| Back to top |
DonJ
23 Jan 2005 23:20 zigbee how to |
| tjalps wrote: |
Hello!
regards! |
Hi
1) Try to search for Zigbee at this forum and you will find some info about Zigbee
2) Go to www.zigbee.org for introductory info
3) There are some good IEEE papers about the subject
Range: 25m should not be a problem. Freescale has achieved link over 300m!
Zigbee kits: Ember, Microchip, Chipcon and Freescale offer Zigbee kits. The Ember stack is pretty neat. I don't know about the others. Try out yourself.
Good luck
| Back to top |
tjalps
24 Jan 2005 11:14 microchip zigbee tutorial |
Hello!
What do you mean that Ember stack is neat?
Regards!
| Back to top |
DonJ
24 Jan 2005 12:34 how to start with zigbee |
| tjalps wrote: |
Hello!
Regards! |
"It seems to function well".
| Back to top |
tjalps
24 Jan 2005 13:15 how to zigbee |
Hello!
Did you buy complete development system from ember or you started working only with Ember IC's?
Regards!
| Back to top |
DonJ
24 Jan 2005 18:17 details of zigbee |
| tjalps wrote: |
Hello!
Regards! |
Hi
Our team recently started on this mixture of external kit and our own technology.
A.T.B
| Back to top |
milojames
24 Jan 2005 21:07 zigbee tutorial |
Take a look at http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=13192DSK&parentCode=ZRP-1&nodeId=02XPgQhCQ6m6cy7103
. I've been playing around with the freescale development kit and it works pretty well. You can get 25m, but you have to build your own antennas. The ones on the eval board are not very good.
| Back to top |
DonJ
24 Jan 2005 23:46 how to start with zigbee |
| milojames wrote: |
Take a look at h**p://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=13192DSK&parentCode=ZRP-1&nodeId=02XPgQhCQ6m6cy7103
. I've been playing around with the freescale development kit and it works pretty well. You can get 25m, but you have to build your own antennas. The ones on the eval board are not very good. |
Is it correct that you need two antennas? It looks like it from the brochure.
Thanks.
| Back to top |
tjalps
25 Jan 2005 8:02 zigbee microchip example |
Which is better EMBER or FREESCALE?
Regards!
| Back to top |
DonJ
25 Jan 2005 9:09 full details of zigbee |
| tjalps wrote: |
Regards! |
Hard to say. You need to work with both to tell. I haven't.
A.T.B
| Back to top |
milojames
28 Jan 2005 0:17 microchip zigbee example |
Yes, the freescale parts have a seperate tx and rx antenna. I used a tx/rx switch to only use one antenna, but I suppose you could also design a passive combining circut since the device never transmits or recieves at the same time.
the chipcon CC2420 is a much nicer part and has the tx/rx switch built in, as well as hardware based encryption, but is more expensive, so I must use the freescale part.
| Back to top |
DonJ
28 Jan 2005 9:19 zigbee where to start from |
| milojames wrote: |
the chipcon CC2420 is a much nicer part and has the tx/rx switch built in, as well as hardware based encryption, but is more expensive, so I must use the freescale part. |
The upcoming parts also from newcommers seem to be better. Hard to say which will be best.
| Back to top |
mitesh
29 Jan 2005 10:31 zigbee where to start |
Hi Do any body have full details on ZigBee. Do any body have extra Freescale development board.
Please support me, i want one.
| Back to top |
DonJ
29 Jan 2005 14:00 starting zigbee |
| mitesh wrote: |
Please support me, i want one. |
I think it is not for free.
| Back to top |
tjalps
29 Jan 2005 16:30 zigbee design kit |
Hello!
Yest that is true. From begining Freescale had limited number of development kits and now he stoped the action and if I'm right you can order development kit for around 99 USD which is much cheaper than Ember and ChipCon.
regards!
| Back to top |
ivoblog
| Back to top |
omara007
Joined: 06 Jan 2003 Posts: 1279 Helped: 39 Location: Dubai
03 May 2005 4:42 how zigbee start |
| I heard that Freescale is distributing its ZIgBee MAC code for free but under certain conditionds or something like that .. is that true ? .. if yes, how can I get to have this code given that I will use it in my masters ?
| Back to top |
