electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
555 Timers - random on / off time
Post new topic  Reply to topic    EDAboard.com Forum Index -> Electronic Elementary Questions -> 555 Timers - random on / off time
Author Message
Davros
Post05 Aug 2004 12:03
I think I have seen somewhere how you can use two 555 timers to make a variable output that makes the high and low times constantly different.
Think it linked the output of one to the input of the other.
Anyone have a schematic / site with this onfo or is there another way to do it?
Back to top
cherrytart
Helped: 5
Post07 Aug 2004 5:16
Walter Jung had an IC Timer Cookbook years ago. I've never seen it online.
National Semiconductor used to have lots of 555 uses in their data book.
If you want variable timing out of the 555 you have to connect a variable signal to the Control Voltage input (or else use non-linear components, like an incandescent lightbulb for a charge or discharge resistor). And the only place to get a varying signal (that is, an analog varying signal) is at the timing capacitor.
So my guess is that you build two monostables and connect their Control Voltage input to the other timers timing capacitor.
Wackiness ensues.
Back to top
cherrytart
Helped: 5
Post07 Aug 2004 5:26
ooops! not monostable, two astable multivibrators is what i meant
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
suru
Helped: 4
Post25 Sep 2007 10:35
REFER OPAMP BY GAIKWAD
Back to top
shiveshdubey
Helped: 1
Post11 Oct 2007 12:11
Re: 555 Timers - random on / off time
there is a lot of resources available on net itself regarding 555 and its applications.
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
555 Timers (5)
555 Timers (12)
Can 555 timers be used as RS flip flops ? (10)
problems with 2 555 timers sharing the same power supply (7)
1 minute on, 3minute off 555 timer (1)
Need 555 timer to start when power is turned off, sort of... (6)
how to calculate time(seconds) with 8051 timers???? (7)
how is Vos (off-set voltage) is random?? (2)
HELP 555 TIMER to switch relay OFF for 20 min ON for 5 sec (1)
555 timer max time (18)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
