electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Duty cycle to voltage...
Post new topic  Reply to topic    EDAboard.com Forum Index -> Analog Circuit Design -> Duty cycle to voltage...
Author Message
masterx81
Post24 Jul 2004 9:08
duty cycle to voltage
Hi to all...
I'm a beginner and I need a simple circuit that convert a signal of 150hz with variable duty cycle (from 0 to 100%) to a constant voltage proportional to the duty cycle...
I have tryed to find in internet, and I think that I need a lc filter (i am not sure...) , but I not say how calculate the values of the components...
Thanks to all!!!
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
hill
Helped: 9
Post24 Jul 2004 9:12
constant voltage duty cycle
Use a R and C combination. R in serial, C in parallel with your load. I think this is the simplest form.
Back to top
masterx81
Post24 Jul 2004 9:18
convert duty cycle to voltage
ok...
mmm... How i can calculate the exact value of the resistor and capacitor?
After the rc I think that i need also a transistor (because the load do not discharge the capacitor before the time), right?
Back to top
batdin
Helped: 3
Post24 Jul 2004 16:12
Re: Duty cycle to voltage...
It depends on your load resistance.
Depends also on the output ripple than can be tolerated.
What is the signal source?Can it supply enough current to the load or should it be amplified beforehand?
Give some details.
Back to top
Einstein
Post24 Jul 2004 17:09
This sounds like a what is used in a chopper. Can you be more specific about the input waveform? If you look on the net for "chopper circuit" you'll find some stuff!
Back to top
masterx81
Post24 Jul 2004 17:22
the input signal is an inverted square wave (normal +12) with a variable duty cycle. The output need to be a variable voltage (form 0 to +5, 0 when the input is @ +12 -0% duty-) depending on the input duty...
I'm considering to use an operational amplifier...
Back to top
dumbfrog
Helped: 4
Post24 Jul 2004 19:33
yes, use an opamp integrator
Back to top
masterx81
Post24 Jul 2004 20:02
Another little qustion...
Sorry for the banality of the domand but...
The opamp insert a little tension to the output(ca 2.5v), how i can remove it???
I'm using a tl074cn (quad opamp) with single supply (+12)
Thanks for the help!!!
Back to top
eternal_nan
Helped: 15
Post24 Jul 2004 20:51
Assuming you already have a DC voltage available to power your circuit, what you are looking for is called a DC-DC converter, they come in several varieties: buck, boost, buck-boost, flyback and other topologies that are mainly derived out of the above 4. There is lots of info about these circuits on the web, search in google.
Back to top
mazelk
Helped: 2
Post25 Jul 2004 7:09
Hi...
Assuming that the amplitude of input square signal is 12 V, you may get first an inversor. If the output sholud be 0 when input signal is 12 V, 0% duty, this may significates that in this moment, input signal is 12 VDC. This improve allows output DC signal increases when pulse width increases.
After this, you can converts the input-inverted-square signal, in a triangle signal, applying, for example, a Miller integrator. Based in triangle amplitude (that is proportional to pulse width), you may get the DC signal with, for example, simple diode-RC schematic; keeping low output ripple.
Typically, this solution should be non-linear.
Back to top
masterx81
Post26 Jul 2004 8:04
Ok, I have find all the information but...
The opamp that I have, also in configuration voltage follower, when are at state low, they are @ ca 2,5volt (not 0...).
I'm using it with +Vcc->12v and -Vcc->Ground...
Whot I am doing wrong???
I need opamps designed for single power supply?
Thanks!
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
How to get 1/3 duty cycle from a 50% duty cycle clock? (14)
Convert Duty cycle to analog voltage (2)
Boost Converter Output Voltage When Duty Cycle is 0.9 (4)
Confused...Duty Ratio VS Duty Cycle (2)
duty cycle (7)
50% duty cycle (8)
duty cycle (9)
duty cycle (8)
duty cycle (3)
50% duty cycle (17)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
