electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
wide tuning range VCO problem
Post new topic  Reply to topic    EDAboard.com Forum Index -> RF, Microwave, Antennas and Optics -> wide tuning range VCO problem
Author Message
gggould
Post10 Apr 2004 4:43
Hi all,
I am designing a VCO with varactor and switching cap to cover 800MHz wide. But I find that the VCO gain and amplitude variations are big problems. Both Kvco and output amplitude increase with the operating frequency...
Any tips or advices?
Thank you very much...
Back to top
flatulent
Helped: 324
Post10 Apr 2004 5:26
Re: wide tuning range VCO problem
Your best bet would be to add an AGC loop. Measure the output voltage after a buffer amplifier and use it to change the bias on the oscillator transistor. Another thing for it to control would be an attenuator.
Back to top
IICCEE
Helped: 2
Post10 Apr 2004 5:36
you may use **several** the varactor ,some place near the BJT-E,some near BJT-B;
and you should be carefully design the buffer in the working band,also add an AGC loop.
Back to top
gggould
Post11 Apr 2004 5:10
Thanks for all your feedback...
But I still don't know how to get a more constant Kvco. Right now the Kvco at high band (~4GHz) is almost 1.7 times the Kvco at low band (~3GHz).
Hi IICCEE, I don't quite understand what you mean. Could you explain the concept a little bit more? Right now I am placing a pair of back-to-back varactor between cross coupled BJT-C for fine tuning.
Besides, is there anything I should look into while deigning those buffer (emitter follower)? I only know I got to check parasitic caps.
Thanks again!!!
Back to top
IICCEE
Helped: 2
Post11 Apr 2004 8:24
i mean not only let varactor between cross coupled BJT-C for fine tuning,but also copuled from BJT-E.and using more than two varactor. (like mini-circuits product)
and also you can using ADS designer guide to do this,and make some modify for you application.
Back to top
VSWR
Helped: 72
Post11 Apr 2004 21:20
Your VCO is tuned over about 23 % frequency range (800 MHz/3.5 GHz). A change of VCO sensitivity Kvco of 1.7 is not unusual in such a large frequency tuning range. And change of output power, as oscillator Q changes during tuning.
Which varacor diode are you using?
How large change of tuning voltage is required for 800 MHz tuning?
What is the change in output power?
Back to top
gggould
Post11 Apr 2004 22:57
Thank you, IICCEE. Now I got it.
I am using NMOS in N_well varactor with 0.3~2.5V Vtune.
"VCO" (not buffer) output changes from .4Vpp to .7Vpp .
Gee, the Kvco change is really a big headache to me.
How can I design the loop filter to compensate the Kvco variation.
Besides, the +- 20% varactor process variation (which will cause about 300MHz shift) also piss me off...
Back to top
flatulent
Helped: 324
Post11 Apr 2004 23:37
As far as the tuning sensitivity goes you have two choices. One is to make the loop parameters wide enough to be stable with all values. The other is to make a compensation circuit which lowers or raises the loop gain at the low or high end. This can be done with a voltage divider with series diodes and resistors in the shunt path. It can also be done with the diode-resistor networks in the feedback of an op amp.
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
lijulia
Post13 May 2004 7:20
how about use coarse tuning to compensate the process Temp variation?
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
VCO tuning range. (4)
VCO tuning range (1)
VCO tuning range (5)
VCO tuning range (6)
VCO tuning range plotting (10)
tuning range of vco in cosmos scope (3)
IC for Wide Range VCO (7)
wide range (2-20MHz) VCO (4)
PLL VCO - freq synthesizer with wide range. 450 MHz to 850MH (3)
Tuning range (1)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
