electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Electronic Power supply load
Post new topic  Reply to topic    EDAboard.com Forum Index -> Professional Hardware and Electronics Design -> Electronic Power supply load
Author Message
hot_chmock
Post15 Mar 2003 21:49
I need to build an electronic power supply load for testing purpose.
Any information, link or diagram is welcome.
Thanks,
hc
Wink
Back to top
flatulent
Helped: 324
Post15 Mar 2003 22:02
high power current sink
The usual method is to make a high power current sink. Start with a power transistor with its emitter or source connected to a small resistor which is connected to ground.
have an op amp -input connected to the resistor and its output connected to the base or gate. Putting a voltage on the other op amp input will control the current drawn.
This other voltage can come from a manual variable resistor voltag divider or a DAC run by a computer if you want dynamic measruements.
Back to top
Jayson
Helped: 17
Post15 Mar 2003 23:58
I wonder do those expensive electronic loads (ProDigit, Kikusui) also use the method Flatulent described? I've often wondered why they're so expensive.
Anyway, these circuit ideas are really useful. does anyone know of any online schematic respositories that have these types of circuits and explanations of how they work? All books out there deal with opamps and transistors, but in seperate chapters, never how to combine them.
Another interesting circuit is the MOSFET switch using two MOSFETs, again no books I've seen have these ready made recipes. An online collection would be a really nice thing to have reference to.
- Jayson
Back to top
Google
AdSense
Google Adsense
Ads
Back to top
flatulent
Helped: 324
Post16 Mar 2003 2:53
simple hobby circuit
What I explained is simple enough for a hobby use. The commercial devices have much more performance and exceed ordinary hobby needs.
For instance, they can draw current with 0V or so across them. They can measure the output impedance of the supply at different frequencies.
Back to top
billano786
Post16 Mar 2003 17:17
Here is something useful.
Sorry, but you need login in to view this attachment
Back to top
SAR
Helped: 4
Post16 Mar 2003 19:34
Load
Try here:
http://www.webx.dk/oz2cpu/radios/dc-load.htm
Back to top
Eternauta
Helped: 1
Post13 Mar 2004 9:46
Re: Electronic Power supply load
In the attached file the schematic of an electronic load for PSU testing. It's interesting the possibility to switch between fixed ampere consumption and fixed Ohm load. It's from a kit that an hobby magazine sell in Italy: "Nuova Elettronica".
Back to top
aslm
Helped: 5
Post15 Mar 2004 20:18
Hi, needed something simular a couple of month ago and built a load with opamps and power mosfets simular to the one described in the link two posts up. Works fine, a bit unstable, but with som extra filtering It has been to great help for my SMPS project.
re Me
Back to top
AL0117
Helped: 8
Post16 Mar 2004 8:51
Check out the TI (formerly Unitrode) design note "Adjustable Electronic Load for Low Voltage DC Applications".
hxxp://www-s.ti.com/sc/psheets/slua045/slua045.pdf
rgds, Al
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
LINE/LOAD TRANSIENT in SWITCHING POWER SUPPLY (1)
Separating a Power Supply from its Load (3)
Electronic Load (4)
Electronic load (7)
Bipolar power supply out of a regular power supply? (4)
Electronic Load Design (6)
To build a DC electronic load (2)
how???? designing an electronic load (2)
how do i design an electronic load.....?? (4)
negative supply load switch (2)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
