electronics forum
Rules | Recent posts | topic RSS | Search | Register  | Log in
Nice I2C asembler routine for PIC16F84A needed
Post new topic  Reply to topic    EDAboard.com Forum Index -> Microcontrollers > Nice I2C asembler routine for PIC16F84A needed
Author Message
traxonja
Helped: 1
Post18 Apr 2004 19:27
i2c pic16f84
Hello,
does anybody have a nice (clean) routine for writing and reading-from an I2C memory device written for MPASM?
I will use PIC16F84A, and 24LC16 (2k) device so 1-byte address will be used, but 2-byte addresses are OK too.
I have this attached routine but it doesn't work Sad , so if you have a nice tested one please post it here.
When I programm the device in PicBasic, it works, but with this routine in MPASM it doesn't work Sad
All best,
Trax
Back to top
Google
AdSense
Google Adsense
Ads
Sorry, but you need login in to view this attachment
Back to top
zmanultra
Helped: 2
Post19 Apr 2004 2:30
pic16f84a i2c
Hi
is what the device that u have a smartcard (gold wafer) caus that cojntains the 2 ICs u talking about.
Back to top
traxonja
Helped: 1
Post19 Apr 2004 9:38
i2c pic16f84a
No, it's only my PIC and some eeprom, in my case it is 24c16.
Trax
Back to top
Kripton2035
Helped: 21
Post19 Apr 2004 14:34
i2c assembler
be aware that if you look at the details of the picbasic language, the i2c routines works well only with hard i2c chips for example 16f876, but not the 16f84...
they work quite in master mode, but quite not in slave.
Back to top
elektryk
Post19 Apr 2004 14:54
pic i2c asm
Look at www.piclist.com huge library of source codes and clues sorted in categories.
Back to top
sam_manchali
Helped: 3
Post19 Apr 2004 15:04
16f i2c
hi,
check out the routines provided by microchip itself, they work fine to my knowleded!!
cheers
sam
Back to top
C-Man
Helped: 73
Post19 Apr 2004 15:10
16f84 i2c
traxonja
a few years ago i programmed a project in PIC assembler which was storing data from a magnetic card reader in a 24C16 using a 16F84.
I have posted the source here:
http://www.elektroda.pl/eboard/searchtopic66923-.html
hope this is useful for you
best regards
Back to top
elcielo
Helped: 6
Post19 Apr 2004 16:23
cardreader with pic16f84
Interface I2C pour microcontrolleur PIC16C84
http://perso.easynet.fr/~chrisg/pici2c.htm
Simple I2C master code for 12-bit series PIC (<=5MHz clock)
http://www.kingswood-consulting.co.uk/pic/i2c.i
Back to top
traxonja
Helped: 1
Post19 Apr 2004 20:04
pic16f84a+24c01
Thanks for the answers. I found a nice routine at www.piclist.com.
And, I couldn't download a file from this forum because I am stil a new user and I don't have any points Sad Smile
Best regards,
Trax
Back to top
elektryk
Post23 Apr 2004 14:52
pic16f84 i2c
You have now Wink
Back to top
mbyka
Helped: 1
Post23 Apr 2004 22:14
pic16f84 magnetic card reader
Hi
I can help you with my sample code
maybe Smile
LIST P=16F84
   INCLUDE "P16F84.inc"
   TITLE " 24Cxx Programming with pic"
EEPROM   EQU 1CH
ADDR      EQU 1DH
DATAI      EQU 1EH
DATAO      EQU 1FH
TXBUF      EQU 20H
RXBUF      EQU 21H
COUNT      EQU 22H
DEL      EQU 23H
SEL       EQU 24H
DI      EQU 7
DO      EQU 6
SDA      EQU 1
SCL      EQU 0
;PortA.0--------->Serial Clock----------24Cxx's Pin:6
;PortA.1<-------->Serial Data-----------24Cxx's Pin:5
;PortB LED outs
   __CONFIG _WDT_OFF & _XT_OSC & _CP_OFF
;========= start======================
   ORG 000H
   GOTO START
START
   CALL PORT_INIT
MAIN
   MOVLW 00H         ;Eeprom write Adress
   MOVWF ADDR
   MOVLW 23H         ;Eeprom  data
   MOVWF DATAO
   CALL WRITE_EEPROM
   MOVLW .100
   CALL DELAY_NMS
   MOVLW 00H         ;Eeprom read adress
   MOVWF ADDR
   CALL READ_EEPROM
   MOVF DATAI,W
   MOVWF PORTB         ;read from Eeprom transfer data portb
   MOVLW .100
   CALL DELAY_NMS
DONE
   GOTO DONE
;================= Port Init ============================
PORT_INIT
   CLRF PORTA
   CLRF PORTB
   BSF STATUS, RP0      ;page1 select
   CLRF TRISA
   CLRF TRISB
   BCF STATUS, RP0      ;page0 select
   CLRF PORTB
   RETURN
;======== eeprom cominication=========================
WRITE_EEPROM
   CALL BSTART
   MOVLW B'10100000'
   MOVWF TXBUF
   CALL TX
   MOVF ADDR,W
   MOVWF TXBUF
   CALL TX
   MOVF DATAO,W
   MOVWF TXBUF
   CALL TX
   CALL BSTOP
   RETURN
READ_EEPROM
   CALL BSTART
   MOVLW B'10100000'
   MOVWF TXBUF
   CALL TX
   MOVF ADDR,W
   MOVWF TXBUF
   CALL TX
   CALL BSTART
   MOVLW B'10100001'
   MOVWF TXBUF
   CALL TX
   CALL RX
   CALL BSTOP
   RETURN
BSTART
   BSF PORTA,SDA
   BSF STATUS, RP0
   MOVLW 00H
   MOVWF TRISA
   BCF STATUS, RP0
   BCF PORTA,SCL
   NOP
   BSF PORTA,SCL
   NOP
   NOP
   NOP
   NOP
   NOP
   BCF PORTA,SDA
   NOP
   NOP
   NOP
   NOP
   NOP
   BCF PORTA,SCL
   NOP
   NOP
   RETURN
BSTOP
   BSF STATUS, RP0
   MOVLW 00H
   MOVWF TRISA
   BCF STATUS, RP0
   BCF PORTA,SDA
   NOP
   NOP
   NOP
   BSF PORTA,SCL
   NOP
   NOP
   NOP
   BSF PORTA,SDA
   NOP
   NOP
   BCF PORTA,SCL
   NOP
   NOP
   NOP
   RETURN
BITOUT
   BSF STATUS, RP0
   MOVLW 00H
   MOVWF TRISA
   BCF STATUS, RP0
   BTFSS EEPROM,DO
   GOTO BITLOW
   BSF PORTA,SDA
   GOTO CLK_OUT
BITLOW
   BCF PORTA,SDA
CLK_OUT
   BSF PORTA,SCL
   NOP
   NOP
   NOP
   NOP
   BCF PORTA,SCL
   NOP
   RETURN
BITIN
   BSF EEPROM,DI
   BSF STATUS,RP0
   MOVLW 02H
   MOVWF TRISA
   BCF STATUS, RP0
   BSF PORTA,SCL
   NOP
   NOP
   NOP
   NOP
   NOP
   BTFSS PORTA,SDA
   BCF EEPROM,DI
   BCF PORTA,SCL
   RETURN
TX
   MOVLW .8
   MOVWF COUNT
TXLP
   BCF EEPROM,DO
   BTFSC TXBUF,7
   BSF EEPROM,DO
   CALL BITOUT
   RLF TXBUF,F
   DECFSZ COUNT,F
   GOTO TXLP
   CALL BITIN
   RETURN
RX
   CLRF DATAI
   MOVLW .8
   MOVWF COUNT
   BCF STATUS,0
RXLP
   RLF DATAI,F
   CALL BITIN
   BTFSC EEPROM,DI
   BSF DATAI,0
   DECFSZ COUNT,F
   GOTO RXLP
   BSF EEPROM,DO
   CALL BITOUT
   RETURN
DELAY_NMS
   MOVWF DEL
OUTTER_MS
   MOVLW .110
   MOVWF SEL
INNER_MS
   NOP
   NOP
   NOP
   NOP
   NOP
   NOP
   DECFSZ SEL,F
   GOTO INNER_MS
   DECFSZ DEL,F
   GOTO OUTTER_MS
   RETURN
END
Back to top
elcielo
Helped: 6
Post29 Apr 2004 23:50
tsa5055.asm
Copieur autonome de mémoires I2C 24C01 à 24C16
http://col2000.free.fr/copieur/cop_indx.htm
I2C-Programm fuer 2,65GHz-PLL-IC TSA5055 for PIC 16F84(A)
http://www.qsl.net/db0mwb/projekte/tsa5055.asm
PIC 16F84 - TIMER PCF8583 - EEPROM 24LC65, COMMUNICATION I2C ET AFFICHEUR LCD LTN211
http://www.asmfr.com/code.aspx?ID=15193
BUS I2C POUR PIC16XXX
http://www.asmfr.com/listecodes.aspx?catid=261
Couplage PIC16F84 & 24C16
http://col2000.free.fr/i2c/protocol/eeprom05.asm
Back to top
hassan1980
Helped: 3
Post07 Feb 2005 21:44
tsa5055 pic
I want a clear program for just reading and writing in serial eeprom like 24C64 with 16f84.
I need your help
Back to top
dragosdiaconita
Post22 Mar 2007 17:04
pic16f84 i2c slave basic
does anyone have an exe file to comunicate with the 16f84 serial out?
pls?
ty for ure kindnes
Back to top
tonybg
Helped: 2
Post22 Mar 2007 17:43
pic16f84 read 24c01 eeprom
Why don't you try Application Maestro.It's a part of MPLAB.Generates many protocols,and explains all the details about hardware and software on the specfic code it generates.Hope it helped:D
Back to top
iman_andeh
Helped: 1
Post09 Jul 2007 4:41
i2c pic16f
how to communicate (read and write) the gold wafer card using other PIC mcu such as PIC16F877A?
i'm trying to build a portable gold wafer card reader/writer...
Back to top
zmanultra
Helped: 2
Post09 Jul 2007 4:45
i2c with pic16f84a
its like programming a normal pic processor....the only difference is that u must creat a serial Comm routine...check out picbasic pro...it has some serial routines...thats the easiest way....or u can use microchip compiler....
hope this helps
Smile
Back to top
iman_andeh
Helped: 1
Post09 Jul 2007 23:58
16f84+i2c
is there any sample code that used to write gold wafer card?
Back to top
zmanultra
Helped: 2
Post10 Jul 2007 0:23
master i2c for pic16f690
dont worry about "gold wafer card" look at it as simply programming a chip....(pic16) have u programed that chip b4....if not, just have a look at the sample code provided (e.g. pic basic is good for beginers)
Back to top
iman_andeh
Helped: 1
Post10 Jul 2007 1:26
pic16f84a mit i²c
yes, i have programmed PIC before, that is PIC16F877a..
about gold wafer card,
i'm really confused what i should do now.
i tend to use circuit below as my gold wafer card reader and programmer
this circuit was grabbed from Silicon Chip (issue 178 (July 15, 2003), by Peter Smith)
but,
i really have no idea about the code. could you give an example code?
Back to top
zmanultra
Helped: 2
Post10 Jul 2007 1:34
i2c pic16f84 meppel
i have programmed the exact same card b4...
the steps to go on about it.
for testing...
(write a serial routine which just outputs a letter every second or somthing...(in pic basic pro its just 2 lines of code...check it out) and then get a software (google it up) to monitor the serial port and have a look at the card(pic processor) is outputing.....
and then u should have a clearer pic of wat the hell is going on
hope this is helping u dude?
Back to top
hulahula
Post10 Jul 2007 2:09
pic16f 628 card reader
http://www.c51c51.com/index.php?lay=show&ac=webboard
Back to top
Arabic versionBulgarian versionCatalan versionCzech versionDanish versionGerman versionGreek versionEnglish versionSpanish versionFinnish versionFrench versionHindi versionCroatian versionIndonesian versionItalian versionHebrew versionJapanese versionKorean versionLithuanian versionLatvian versionDutch versionNorwegian versionPolish versionPortuguese versionRomanian versionRussian versionSlovak versionSlovenian versionSerbian versionSwedish versionTagalog versionUkrainian versionVietnamese versionChinese version
Page 1 of 1 All times are GMT + 1 Hour
Similar topics:
PIC asembler i2c routines for 10 or 8 MHz (2)
REQ: Philips LPC9XX I2C slave C routine, interrupt driven. (4)
Needed Code Examples for I2C Slave Mode (1)
DC motor rpm control using pic16f84A !!code needed (7)
need asembler manual fro iar z80 (1)
C Routine for RS232 (3)
Hi-tech routine for debouncing a button (3)
hi tech routine for LCD print (11)
need adc display routine for PIC (1)
sorting routine in assembly for PIC (8)
Abuse || Administrator || Moderators || Support us || sitemap
topic RSS
