why 'beta' of transistor increases with temperature?
Bhanumurthy
Full Member level 5
Subcontinent
Can anyone explain why β of a transistor increases with temperature and base-emitter voltage decreases with increase in temperature?
Regards
It because of the fact that base transport factor(which constitute mobility and recombination lifetime) reduces with temperature, in turn causing decrease in base current, and therefore an increase in β.
Reactions: YD125
    YD125
I would attribute increased beta to the increase in thermal injection
BJT's are formed from doped semiconductors. Semiconductor properties can be quite sensitive to temperature. For a conductor, resistance increases with temperature. In a simple model, this can be thought of as due to the increased motion of the atomic cores that inhibit the flow of conduction electrons.
However, the resistance of a semiconductor decreases with temperature. To understand this fully requires some advanced knowledge, but is because though the atomic cores of the semiconducting material are moving about more, extra charge carriers are also being generated. The extra generation outweighs the increased motion of the atomic cores.
A reasonable explanation of this is given in an old book:
"Analogue and Digital Electronics", Ahmed and Spreadbury, Cambridge University Press (1984)
