tahir4awan
Full Member level 4
Hello,
On Friday we received an assignment. The calculation was not a problem but the theory behind it was confusing. My teacher showed me two circuits arrangements. In one only series resistor was used and in other voltage divider was used. The radio was working good only in voltage divider circuit because it was stable.
The radio was using 6V. The problem with this is, the more current will flow through R2. I mean, when you change the volume to high, it will require more current to generate more sound. Secondly if you change the resistance of the radio, which is parallel with R2, then the overall resistance will be changed, and hence we have too low voltages. So how come this voltage divider is working, while radio need constant 6V? Also a term q is used. Which should be more than 5 to achieve stability.
Thirdly, I have not noticed it before, but what changes the Potentiometer (volume). Because it has positive resistance, which means if you turn, it will create more resistance, but we have more sound.
Any help from someone.
Thanks
Thanks
