Using the HFSS feature mode solver for an open structure
x529
Junior Member level 3
Problem: Use the HFSS feature pattern solver for open structures
I'm thinking about how to use the HFSS eigenmode solver for open structures. I learned a lot from the website, thank you.
These links may help answer this question, but I can't answer it.
(https://www.edaboard.com/threads/hfss-eigenmode-solver-for-open-structures.364313/
https://www.emtalk.com/tut_3.htm
https://www.edaboard.com/threads/hf...w-cut-off-lh-propagation.393623/#post-1687909)
For open structures, we may need to add PML and air tanks to simulate. But I don't know how to set the PML parameter in the structure.
For example, how do you simulate a feature model solver when a wave guide structure is transformed into a semi-closed model? (Additional analog model)
Expects your response.
Thank you very much.
Good luck.
  • demo1.zip
You want the characteristic mode solver, not an eigenmode solver. The eigenmode solver is for closed (or mostly closed) structures.
ok, I will try it. Thank you very much~
