You should try to phrase a clear question.
o15 <= i(15);
o14 <= i(14);
o0 <= i(0);
Each input bit has to be copied to an individual logic signal.
Code:o15 <= i(15); o14 <= i(14); ... o0 <= i(0);
You're the champion of unclear questions! Without specifying a logic operation, the signals can't be merged.i know this, you dont understand my question. I have only 1 output with width of std_logic.Can I somehow merge inputs into this 1 output?
This operation is undefined O <= I; as long as you can't give a rule for reduction of the 16 bit vector to 1 bit.
E.g. I may be "0001001001110011", what do you want as result for O, '0' or '1' ?
There are actually 65536 possible bit combinations for the input vector. If your not sure about your intention in reducing it, how should know?I try this logic too, but i am not sure that it is the right one
