Transfer Function of DC Motor
I do not see parameters like motor viscous friction constant for example
Depends on the data sheet completeness. Most important parameters are emf and torque constants. They can be derived from a good datasheet. Also friction constant from the no-load current. Rotor inertia and inductance are rarely specified and must be measured or estimated.
I have attached the image of DC motor datasheet. Could you please guide, how to calculate motor viscous friction constant ,electromotive force constant
It's not a motor, it's a generator.
Klaus
No it's a motor (see item 20). Item 7 specifies the power supply.
The datasheet clarifies that the motor has among other features variable excitation and a compound winding, thus the simple DC motor model derived in the link in post #1 doesn't apply. Refer to an electrical machines text book for a detailed analysis.
Indeed you are right. I misinterpreted the "generator" and "excitation" ...
Klaus
Yes, It is separately excited dc motor. Would viscous friction and emf depend on type of motor(simple or compound).
Sketch a complete equivalent circuit of the motor with all windings. You'll realize that there more parameters involved than with the simple PMDC motor analyzed in the post #1 link.
There are no parameters in the above datasheet that allow estimation of friction constant.
ok. Now one last question. I wanted to know the dimension normalization in a typical DC motor control system. For example inertia is usuallyt given in kg-m2 and speeds are usually rad/s. Can we subsititute these values as it is or any conversion is required?
