hank_the_wolf
Newbie
I have designed the following circuit. It's supposed to be a low pass microstrip filter and a 50 ohm microstrip transmission line. Individually, each work with wave ports. However, I need to use lumped ports because I can't get accurate readings from the wave ports being the size I need them to. (I need to put them very close together for cross talk) The only conductors are the traces and the reference plane. The integration line I set goes from the top of the reference plane to the top of the two lines (the conductors are boxes .012 ish mm thick.)
When I put the lumped ports together (red sheets), I get the following error messages:
