simulate floating point cores in xilinx ise 9.21
vgs
Junior Member level 1
Can anyone please help me to simulate the floating point cores in xilinx ise 9.2i using modelsim pe 10.c
please reply
thanks in advance
Initially the problem was that the modelsim couldn't give any results.now i'm getting some results.but i'm confused with the floating point arithmetic.can you help me in that?how to convert integer numbers to floating point numbers(32 bit single)
you will have to use an integer to float IP block if you want to synthesize it.
