send the program in embedded c to run dc motor
CHANDAN10
Junior Member level 2
what a descent way to ask something......amazing should be appreciated...
FYI: codes are not readily available in market as per your application.
Your question would've made some sense,had you mentioned the basic specifications of your project.
regards,
hey.... you can use PORTx=0xff as o/p to dc motor and uu have to set the DDR value for thatparticular port..
Be more specific..type of motor,current,voltage,type of uc you are using (pic,avr,8051,motorola) etc etc..and change the way you ask for something..
Do you guys honestly think after 3 years he still looking for a solution?
