S-parameter simulation software
Paul98
Member level 5
Hi, I need to simulate some circuits with components for which the S-parameters are provided. The question is:
Are the S-parameters sufficient to simulate the component? What program can I use for these simulations?
thanks
If the s-parameters are given for ALL Components, s-parameter analysis is sufficient for your circuit.
If you don't have any budget for the RF and Microwave Analysis Software ( they are extremely expensive ) you can use FREE software.
or
This is ADS like Analysis Software and it's very efficient for essentials.
Reactions: Paul98
    Paul98
RFsim99 is also for free..
Follow the link, launch the program RFSim99.exe (don't need installation), press the 2 ports box, load the s2p file, place the in/out ports and ground, and press "simulate". You can set for rectangular or polar plots, Smith chart...
