brunofunchas
Full Member level 3
I have tried with the cable IBH S5-USB-Adaptor, communicate with the PLC above, but I can not! The response of the technical assistance of IBH Softec is that the port of the PLC may be damaged. I'm using S5 S7 for windows version 6.6.1. The cable is good because I've used in other PLC's.
Configuration used: Baud rate: 9600, Parity, No Handshake, Data bits: 8 Stop bits: 1
My question is if I can try with the software PG2000? How do you configure the serial port? Is there another alternative?
I also have the cable from Siemens AG / TTY 6ES5 734-1BD20, but the result is the same when used with a converter Serie / USB.
Regards,
Bruno
Regards,
Bruno
