OPEN URL with SIM300c
sakaz
Junior Member level 1
sim300c at command
Hello Forum,
Hope you are all doing well.
I have just recently got the SIM300C module and the purpose of using this GSM/ GPRS module to send periodical data from difference locations to the website running sever database. I have worked with the ASP and made the database. I have installed some temprature / gas sensros different places and i want to upload their data do the website at central location. so the person sitting at the central location can check if everything is going well.
I have made the ASP /VBA script to just simply run if you got my idea. for example:
if we run this in the explorer:
http://users1.nofeehost.com/zeeworks/xt_email.asp?prefix=srn&text=12345678901
then the ASP script will run and add the record in the server database and reply confirmation.
If you will go to:
URL : http://users1.nofeehost.com/zeeworks/
username: admin
password: admin
and CLICK on the VIEW SMS DATA then you can see at the end the new entry with date and time. It is just an idea i had made i will make it more better.
1. Do you think this is the right way to upload data in the database.
2. How i can run the above http URL connecting through the GPRS SIM300C AT Commands.
I hope you understand what i want and could you please help me to start my this proejct.
Regards,
Shan
sim300c web based
Helo gsmman
thanks for your reply. Yes, i have got it already and done and i also tried to open the www.google.com and other random websites and i got it how does it works. Great thank you.
Now, i want to send an email through smtp server using sim300c gprs module. I have searched on the internet and found some smtp procotols like this.
AT+CIPSTART="TCP","SMTP MAIL SERVER IP ADDRS","25"<cr>
OK
CONNECT OK
220 SMTP .................. >>>>>
at this stage when i type anything and press ENTER <CR> then i got ERROR. why is that? How i can send the email.
Waiting for your positive reply.
Shan
open url at command phone
You must send each line of data using the "+CIPSEND" command:
>> AT+CIPSEND            - Issue Send Command
<< >                       - wait for module to return'>' to indicate it's ready to receive data
>> EHLO test.com           - send data (terminate with CTL-Z)
<< 250 OK                 - response from SMTP server
>> MAIL FROM:Admin@test.com    - send data (terminate with CTL-Z)
<< 250 OK - MAIL FROM [email]Admin@test.com[/email]  - response from SMTP server
sim300c send data to web
Hello,
Thanks, yes i have gone through the web search and found the SMTP , POP3 protocols and i have tried to use both and i have successfully, retrive email from the pop server. But when i try to send email through my smtp server i got an error:
HELO me@myserver.com --- SMTP welcom nice to meet you
MAIL FROM:<me@myserver.com> --- SMTP SENDER OK
RCTP TO: <receiver@myserver.com> --- SMTP RELAYING DENIED ?????
I have a question, how i can connect any smtp server without Username or Password. i could not understand. if it is without username of password then anybody can use someone smtp server.
Please clarify.
Shan
atdt+
sakaz said:
Hello,
Some SMTP servers do not required authentication, some do. If your server does then you need to send the authentication commands before constructing the Email - see this link for a good description of various authentication methods:
https://www.fehcom.de/qmail/smtpauth.html
_____________________________________________________________________
'Connecting the World...One Machine at a Time'© - www.SoftwareConceptsInc.com
sim300c code
Thanks Gsmman,
This is really great link you have provided to learn and understand about the mail authentication. I have tried with my own web site / smtp. mail server. I have succssfully sent and receive email through hyperterminal using my GPRS modem.
Once again thank you so much. I will be here again to learn more from this forum.
Regards,
Shan
