Op-Amp Summing Amplifier Not Working
FreshmanNewbie
Full Member level 6
I have this below circuit Op-Amp summing amplifier with its below result:
enter image description here
But in my actual circuit all components are the same except the Op-Amp. I am using this Op-Amp part in my practical circuit :
V1 - 22V V2 - 1V pk-pk Sine Wave Output Voltage - 20V
Output Current - 50mA.
Actual Circuit Output Waveform :
Why am I not getting the summed output as in the case of simulation result?
For starters, you’re showing a 2V P-P input, not 1V. Have you verified your connections? Your power supply voltage? How are you getting 50mA load current with no load? You Also don’t show the zero point for C1.
your values make no sense. You did something wrong, but currently don´t show us.
How can the output current be 50mA when there is nothing else connected than the 100k resistor?
--> Show a photo where we can see all wiring including power supply and measurement devices.
Klaus
